Question about Jasco GE 98903 2.1 Speakers
I need to reinstall the jasco 98903 2.1 speakers on my win xp.
I recently just had to redo my hard drive and i did not save the drivers for the jasco spaekers. I cannot find the drivers I need to reinstall. Help I have no sound.
  • 32 Answers
Speakers in a sense do not need drivers, the component it the pc has to have them to provide sound. So find the drivers for your sound card on the disc that came with your computer. Or go to the product website and find the drivers there. After that u should be A for away.
Posted on Jan 04, 2010
71 years old, would like a step by step procedure to transfer the content of my computer to the hard drive, than i would like to remove & reinstall window xp. This would greatly be appreciated. Thank...
Hi
Transferring file from your computer to external hard drive is very easy, just copy and paste all the files you needed to the external hard drive.
Reinstalling Windows XP would be quite difficult. Make sure you have Windows XP installer CD and all the utility hardware driver of your computer e.g. Chipset driver, Sound driver, VGA driver, WAN driver, LAN driver and others. If you do not have the Utility drivers, just download the complete set of utility driver in the internet. Most of them are free to downloads.
Here is the procedure with video on how to reinstall the Windows XP operating system (step by step) http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 20, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have Mercury 2.1 white speaker.It works fine for half an hour but after that the woofer's sound stops-start frequently at highest bass but when I reduce the bass It works normally with no distortion.
If highest bass means you are boosting the bass for effect then it may be some form of speaker protection cutting in.
The most likely is a Polyswitch, which increases in resistance as it heats up when too much current is going to the speakers. The sound resumes when it has cooled down.
Feb 11, 2011 | Jasco GE 98903 2.1 Speakers
When Windows XP tries to load, I get the following message: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." My...
indicates that the hard drive is starting to fail
save everything to an external hard drive
have the system tested by an computer repair shop and if faulty install a solid state hard drive that has no spinning disc
also up grade to win 7 operating system as win xp is no longer supported by Microsoft and many other products are not compatible with win xp
Aug 10, 2017 | MSI Wind U100-423ES Notebook
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
BSOD when not doing anything
Typically this is a driver issue. See if you can start Windows in "Safe Mode" and look for conflicting drivers. The Windows SDK will help determine the BSOD issue if you copy the information doen. The SDK's are avaialble from Microsoft.
Apr 30, 2009 | Microsoft Windows XP Professional SP2
Reinstalling XP
Download the sata drivers to a bootable disc.Then load xp disc and boot from it when entering it will ask for additional(sata)etc. drivers load disc with new sata drivers .put xp disc back in and tell it to install to disc.RICHARDM69
Dec 03, 2008 | Computers & Internet
Won't boot
The error means that the computer is not seeing the hard drive.Hit F10 to get into BIOS and check that your hard drive is showing . If it is hit ESC and tell it to save settings. Then restart the PC.
If your hard drive does not show in BIOS, there is something wrong with it. It may be co-incidental that canceling the scan caused your hard drive to fail.
You can try to do an XP repair. Boot your XP cd:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstall the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Compaq Presario R3000 Notebook
I recently had my hard drive redone and need to reinstall a ge 98903 2.1 pro speaker system. I have no install disk and can find no driver or software info. to download on the net . Help without this i...
do you have Onboard soundchip? or pci slot sound card?
if you have onboard soundchip..just try to install your motherboard cd installer,the sound driver is included in it. if you lost the cd,try to download it from its brand website.
if you have pci slot sound card. try to find from the card its name,brand and model and try to find and download the driver from the net.
hope you'll not lost... ;-)
Sep 25, 2008 | Computers & Internet
Jasco GE 98903 2.1 Speakers Logo
94 people viewed this question
Top Jasco Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jasco Audio Player and Recorder Expert? Answer questions, earn points and help others
