Question about Samsung SGH-D900 Cellular Phone
Buttons Locked when Phone unlocked?
When I slide the phone down, it says Unlock in the left bottom corner as It should. When I open the phone it unlocks itself, but no buttons work only if I hold in the Red Button to turn off. Can anyone help. This only came about today. Never had aproblem with this phone before.
  • Anonymous Sep 26, 2008
    i have the same problem..all buttons of my fone are lock and aint workin except for the on/off button..and my tones are also aint workin cant hear any sounds from it..i have to used my usb head set 2 talk 2 sme1 wenever smebody calls..any1 please help..tnx
  • acidrain_tof Sep 26, 2008
    i have the same problem..all buttons of my fone are lock and aint workin except for the on/off button..and my tones are also aint workin cant hear any sounds from it..i have to used my usb head set 2 talk 2 sme1 wenever smebody calls..any1 please help..tnx.
  • 30 Answers
Guys,
looks like 1 of 4 issues
LCD issue (trust me it does make sence)
Main FPCB Faulty
Software issue
Liquid Damage
Take it to your nearest carphone warehouse [carphonewarehouse.com/repairs] and you are probably eligable for a FREE repair under manufacturers warranty [evenb if you bought it elsewhere]
Posted on Sep 28, 2008
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
Jul 11, 2014 | Casio G-zone Commando
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
How to reprogram my sony ericsson k800i
Instructions
Obtain the unlock code for your K800i if the phone is locked. You can get the code from an unlocking service, or from the carrier that originally sold the phone.
Turn off the K800i and turn the phone over.
Remove the battery cover by sliding it toward the bottom of the phone. Lift the battery from the bottom and set the battery cover and battery aside.
Remove the old SIM card by sliding it out from under the metal clip. If you have an unlocked K800i, all you need to do is insert the SIM card from your new carrier. Otherwise, leave the SIM out and reinstall the battery and battery cover.
Turn the phone on and wait for it to boot up.
Press left on the navigation pad and press "*" twice, then press the left arrow again. The phone will display "Personalize with MNC2."
Type the unlock code and wait for the phone to reboot.
Turn the phone off and insert the new SIM card.
Jul 22, 2012 | Sony Ericsson K800i Cellular Phone
How to unlock?
To Unlock the Sony Ericsson W910I Model mobile from the Network lock You can use the Unlock Code You can get the Unlock Code at
http://www.wickedunlock.com/sony-ericsson-w910i/rs11wp9/ and Unlock the mobile following the Free Unlocking Instructions Below............
Sony Ericsson W910i Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson W910i mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W910i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W910i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson W910i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2
Oct 20, 2010 | Sony Ericsson Walkman W810i Cellular Phone
My metro motorola ve240 is locked and i don't know the lock code
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Jul 09, 2009 | Motorola Mobility W375 Cellular Phone
The nokia n95 won't unlock when slide is open and no lights
There is a possibility there is a problem with the ribbon of the slide let a technician check the ribbon of your phone.
Jun 09, 2009 | Nokia N95 Cellular Phone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Wharfedale phone - unlock the keys.
Press the Star Key and hold down
Thanks
Dec 06, 2008 | Lands Phones
Sidekick Password Problem
Try this
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
Oct 22, 2008 | T-Mobile Sidekick ID Cellular Phone
Cant find reset button inside scanner
There is a lock/light key at bottom left hand corner of buttons hold that down until it beeps and the buttons should be unlocked
Jul 27, 2008 | Radio Shack Pro-82 Scanner
Samsung SGH-D900 Cellular Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
