Question about Gb Electrical 100 Amp GE Load Center
  • 653 Answers
I would tend to agree with "Tripleauto". If you do not disconnect the electrical supply to the house, you run the risk of having 240 volts at up to about 75 KVA coursing through your body. Needless to say, before the transformer blows out or someone cuts off the power, your corpse will be mostly ash. Call the power company to co-ordinate having the power turned off while you or your electrician do the work. Once the power is off, swapping out the main breaker is a relatively simple job, assuming you can find an exact replacement. If there is no exact replacement, as in the panel is fairly old and the breaker is no longer available, you will end up having to replace the whole panel or add a 125 amp breaker in a separate enclosure in an accessible location between the meter socket and the breaker box, preferably within reach of the breaker panel. The International Residential Code requires a disconnct where there are more than six breakers needed to turn off all power to the dwelling. Check with your local Building Code office before doing anything.
--Peter Nomikos, International Code Council Master Code Professional
Building and Zoning Director, City of Mauldin, SC
Posted on Feb 26, 2009
  • 1,450 Answers
I dont mean this to sound arrogant. but if you have to ask you might be best to have a professional to do it. the wires coming into the box will be hot without being able to pull meter off of house to disconnect. the panel has to come off and many are different
Posted on Sep 29, 2008
I need to know fuses box
Copy following link to see basic circuit breaker box.
It appears you are connecting home automation to to breaker box.
Remove one wire from each circuit breaker. Connect this wire to relay. Then run new wire from relay to circuit breaker.
When the relay turns ON, then that will complete circuit to each circuit.
This will work for 240 volt or 120 volt or 277 volt single-phase split phase..
Match wire size and circuit breaker
Nov 22, 2012 | Heating & Cooling
What main breaker
Look at label of marking on breaker box.
Square D would have D with a square.
Take one of the individual circuit breakers to local box store and see which brand breaker matches.
Or take circuit breaker to electric supply house and see who sells that main.
Not all mains are available.
And if main was getting hot, it might have damaged the busbar so whole panel needs to be replaced.
Oct 27, 2012 | Electrical Supplies
I have a 125 FPE box currently the combined total of all breakers presently in the box is 190 amps. I am wanting to replace a single pole 20 with a single pole 40. Am I already maxed out or do I have room...
You can add the breaker.
The key is total electric use.
As long as total consumption does not exceed amps shown on main breaker, then the new 40A breaker installation is ok.
If total consumption exceeds main breaker, then the main breaker will start to get hot and then trip.
Put hand on main breaker and feel for warmth.
The main should not feel warm.
Consider upgrading to 150A or 200A service.
Aug 22, 2011 | Connecticut Electric UBIF040N FPE...
There was no grond bus installed
You can buy ground busbar at home center or electric supply and install in main box.
Or go back to seller and swap out for new box that is complete.
Feb 16, 2011 | Siemens Murray 125 Amp Circuit Breaker...
200 amp breaker is melting and power is flickering in house
Usually this is a defective breaker, possibly caused by water intrusion into the panel. This is NOT a do it yourselfer job -- refer this to a professional who knows what they're doing. The meter base needs to be pulled to cut the power to repair it and you are dealing with power that has virtually no fuse or breaker protecting it. If that sounds dangerous, there's a good reason -- it is. I get unnerved doing these. I hope I've helped you, though maybe not the answer you were hoping for.
Feb 14, 2011 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
We have a Cutler-hammer CH2100 main breaker that is very old and started arcing in the box and cutting out the electricity at any moment that it wanted to. I found out that the clips on the back were not...
I was able to go online and locate numerous sites that offered the ability to order the CH2100 and also the CH2100x main breakers. You could also take the breaker to an electrical supply and see what they have to offer as a replacement, but be sure that the connectors in the panel are not damaged before purchasing and installing a new breaker.
Jan 24, 2010 | Cutler Hammer 125 Amp Main Lug Indoor Load...
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
I have a home built in the 50's. circuit breakers are pushmatic. 7 breakers on a side. The locking bar down the center will not allow me to replace 2 single pole breakers with double pole. It's for an...
You need to put in what we call a sub box. This should be done by a licensed electrician, but if you really want to do it yourself you will need a distribution box some wire and it has to be connected directly to your main lags from the meter box, this box will have a main breaker built into it and spaces for additional breakers, depending on your existing wiring the electrician might chose to wire the additional box directly to your meter base and not your existing box. Either way you really should seek local professional help on this project, just for your safety and to satisfy your home-owners insurance.
Have a great day..
Mar 06, 2009 | Connecticut Electric & SWITCH UBIP130...
1 side of 220 v line drops out - no main breaker reset
sounds to me as if you are losing one side of the line inside the meter enclosure , possibly due to lose connection or corrosion on terminals in base i think i would remove meter and have a look see if you are not comfortable to do this have an electrician to do ck
Dec 31, 2008 | Siemens /ITE 100Amp 3-pole molded circuit...
Gb Electrical 100 Amp GE Load Center Logo
3,109 people viewed this question
Top Gb Electrical Electrical Supplies Experts
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
