Question about ASUS P5VDC-X Motherboard
Cant Get Sound from SPDIF Optical Output
I have an Abit IP35 motherboard with built-in SPDIF optical output, and a Technics SA-DX940 decoder/amplifier (which can decode DTS and DD) that i want to use with my PC. I have conencted my amplifier to my motherboard's spdif output with an optical toslink cable. (Note: I'm using Vista Ultimate 32bit SP1, motherboard has Realtek ALC888 sound chip and ive got the latest drivers).
I have also set the digital output as default sound device.
Now when i goto Control Panel and Sound Properties and press 'Test' button i hear no sound and my amplifier shows no sign of its getting any signal.
BTW; I can see the red light at the end of optical cable... Also, my amplifier shows a DTS or a DD logo when its operating normally and getting a digital signal.
But when I Test thru my PC, it shows nothing and produces no sound. This is also same for DVD and .mkv with surround sound playback from my PC.
How can I get SPDIF output to work???
  • Bonio Mar 27, 2009
    When trying to connect a sony minidisc recorder to an abit IP35 MoBo there no audio and nothing on th bar graph. I could find nothing in the bious or software to enable this feature. I just hope together we may find a solution if we put our heads together
Please help me with my problem regarding SPDIF out from PC Asus P5VDC-X model
Best Regards
Gerry
Posted on Nov 27, 2008
  • 52 Answers
How should you connect your CD player to your av amp (both Technics) using an fibre optical cable?
It sounds like your CD player does not have an optical audio output. If so, you will need to get a "Digital to Analog Audio Converter". You can find them on eBay or Amazon for as little as $10. Connect your CD player's analog/RCA-style stereo cables to the converter.Then connect the converter to your receiver with a single optical cable. 6_20_2016_11_27_39_am.png
Jul 01, 2015 | Audio Players & Recorders
HOW CAN I CONNECT A MIXER TO A TECHNICS SA-DX940 AV
I used the manual downloaded from http://www.manuals365.com/technics/sadx940.html
Try using the final stereo output of the mixer as the input to the CD or Tape or VCR inputs.and use the switches on the fromt of the DX940 as necessary.
The specificatios state input sensitivity is 27 mY so your mixer needs a low output..
No reason it shouldn't work.
Sep 18, 2014 | Technics SA-DX940
Technics SA-DX940 Digital optical audio input
When you say you have sound from the BD prior to disc load... where (TV and/or receiver)? Initial wake-up audio is usually 2-channel.
Describe the optical audio connection input to the receiver and any other audio paths that are attached.
Do you have other multichannel sources you could use to test this, like a cable TV box?
There's an obscure setting in the receiver called PCM Fix (on Page 21). Give that a look.
Jun 07, 2010 | Technics SA-DX940
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Feb 21, 2009 | Gigabyte Computers & Internet
SA-DX940 recently stopped recognizing digital formats
Make sure you are using a digital connection, optical or coaxle cables must be connected, setting on receiver must match cable being used
Dec 18, 2008 | Technics SA-DX940
Sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
Jun 11, 2008 | Technics SA-DX1040 Receiver
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
ASUS P5VDC-X Motherboard Logo
1,140 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
