Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator not agitating
The agitator on my whirlpool utimate care II is not agitating the cloths. it is moving very slightly back and for but not at all like it should. What do you think the problem is?
Thank you
Replace agitator dogs, which should be available at your local appliance parts store for around $10. Replacement takes about 20 minutes (for a Whirlpool washer, at least.) Remove the center filter and you'll see a bolt (11 mm in the Whirlpool.) Remove the bolt, which you may be able to do with hand-turn socket wrench unless you have an extension for your ratchet. Removing the entire plastic agitator assembly is easy when tugging from below.
This next part may note be needed, but: Once you have the assembly out put it on the floor and stand on it. To remove the free moving part of the agitator, grab the fins and give it a good tug or two to free it from the lower assembly. It may take a bit of effort. Remove the inards, replace the four dogs, and reassemble.
It was *really* easy to do...and certainly a lot cheaper than having someone come out or, as we thought we were headed, to replace the washer.
For even better description: click here
Posted on Sep 27, 2008
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
The center part that adgitates does not rotate as i think it should can i tighten it somehow
You need to remove the screw from the center of the agitator and pull up on the agitator from the bottom , to remove it . Seperate the 2 piece agitator , and replace the 4 agitator " dogs " . Reasemble . The " dogs " lets the top section of the agitator only move in 1 direction causing the clothes to " tumble " . OR , take the complete agitator to a parts house and they will install them for you .
May 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Sep 23, 2009 | Whirlpool Washing Machines
The agitator does't work on the Whirlpool Utimate II & this washer is about 7-8 years old
You must replace the agitator dogs. Pop the top cover of the agitator to access the 4 defective parts. They are pear shaped.
Tools required.
Feb 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator is weak
you need to remove the agitator, then pull the top half off, replace the dogs inside the cam, and re assemble it, you can find a kit online for a few dollars.
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator slipping
change your agitator dogs in agitator
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate Care II problem
IF THE PROBLEM WITH THE AGITATOR IS THAT IT DOESNT HAVE THE POWER AS BEFORE IT SOUNDS LIKE THE AGITATOR DOGS NEED REPLACING.GOOD LUCK
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care ll Quiet wash Model # LSQ9564SQ0
The ***** part of the agitator is supposed to ratchet in the clockwise direction. this is normal. If you can spin it in either direction (turned off) then you need a set of agitator dogs.
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator
the agitator is supposed to do that in wash dont worry
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
