Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
D link dwl 700ap
I k'nt acess my d link, i forgot ip adress. can yuors help me to acess then?
The default IP address of most Routers is 192.168.0.1 and subnet 255.255.255.0
If you have setup the router earlier with you own network addresses that are different than the default you will have to start again from the beginning and push your routers reset button long enough so the router will reset to the default or factory settings. Then set your computer to automatically get its IP from the router via DHCP. If you have set the router to allow UPNP then you might be able to invoke or CALL the router by right clicking on your LAN connection in the Network connections page. This is if you are running windows. Mac or linux is different but the idea is the same. Hope this helps.
Posted on Sep 25, 2008
I have D-link Airplus DWl 700AP Accss point I can't Access it by brower although I write 192.168.0.50 so I want change the password but I can't could you help me ?
Hi. Thanks for your question.
I believe default IP for your router is 192.168.0.1 or 192.168.1.1
Please try both. Once you are asked for username and password put "admin" in username field and leave password box empty. Hit Enter and you should be able to access your router's settings.
I hope this helps. Please don't hesitate to ask more questions. Thank you for using FixYa
Dec 08, 2010 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
I want the ip to access my router so i can change the default name n put security
You can locate your router's adress with this easy trip:
Hit start - run - cmd. At the new black window that will appear type "ipconfig" without the quotes and hit enter. The system will reply with the the details for IP Adress, Subnet Mask and Default Gateway. The ip adress for Default Getaway is your router's ip adress. This photo may help you:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 01, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
My PS3 says that I have 100% signal stength to internet. I don't have the WPA key to get in when I try to connect wirelessly. I am renting a condo and the owner forgot the passphrase. I do have the...
connect to the computer via lan cable, acess the configuration utility by typing the ip adress in the web adress box and then choose the wireless sucurity tab.
Mar 06, 2010 | D-Link DIR-628 Wireless Router
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
Unable to update firmware
Your router latest Firmware I can see on D-link website is 1.02
If you are referring to German web site page showing a dwl-g700ap_fw_revB_v213b06.zip file be sure to follow the instruction to UNZIP the web_dwlg700ap_v200_r11_0408.bin file:
DWL-G700ap Firmware Update
- Browser starten
- Konfiguration des DWL-700ap aufrufen (Standard IP 192.168.0.50)
- oben auf Tools
- links auf Firmware
- auf den Knopf Durchsuchen klicken
- die Firmware Datei (web_dwlg700ap_v200_r11_0408.bin) auswählen
- auf Apply klicken
Wenn die Firmware installiert und der DWL-700ap dann neu gestartet ist klicken Sie oben auf Tools/System/Restore to Factory Default.
Danach ist die Firmware übernommen.
If you did not unzip the bin file router cannot run it as firmware update
More over be sure to run the update via LAN cable connection (no WLAN)
Jan 24, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Recover my code for wireless internet
We will try a  hard-reset the D-Link Air DWL-700AP to the factory default settings, please dothe following:
Locate the reset button on the back of the DWL-700AP
Use a paper clip to press the reset button
Hold for about 5 seconds and then release
After the DWL-700AP reboots (this may take a few minutes) it will be reset
to the factory default settings.
then do a fresh configuration,
http://209.85.175.104/search?q=cache:Hm3Vs8XnH3QJ:wireless.cisbg.com/soft/Dlink/dwl700AP/Manual/dwl700ap_manual_102.pdf+D-Link+Air+DWL+700AP+802.11b+protection+code&hl=en&ct=clnk&cd=1&gl=in
the above link is the installation guide for setting up your Dlink wireless
Oct 07, 2008 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
209 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
