Question about Motorola Mobility RAZR V3
Please help me
My phone is coming on but i am not seeing anything, i think it has something to do with the skin that was deleted
    Brigadier General:
  • 7,752 Answers
What you can do is have the firmware reflash on the phone to correct this issue.
You can have this done online at modmymoto.com
Posted on Oct 05, 2008
I put a new skin on my motorola razr v3 and it had to reboot but now he stays on reboot
hi, the new skin you are referring to, came with the phone or you installed it? if you are the one that installed it, all you need is try switch off the phone see if it will come on after which you try delete it cause it means it is not compactible with your phone.
Jul 16, 2010 | Motorola Mobility RAZR V3
Camera not detecting
ya something wrong with the acble try replacing the cable
Sep 14, 2009 | Samsung SGH-U600 Cellular Phone
How to install a themes or skin for motorola RAZR v3x???
IF YOU WANT TO INSTALL SKINS/THEMES on your phone. Get Skin Manager v.0.51..
you need skin manager v0.51 also the driver for motorola. downloads themes then extract it. open skin manager wait until it reads your fone then choose menu files,
if downloads button is clickable
HERE IS SOME GUIDE
click it choose the extracted skin just click the file you will see specially the .SKI
then go to SKIN on upper left corner
look for install dont check anything
look for the file on your skin extracted file then install it.
wallahhhh installed
after it click "more" button on lower right then click restart phone
make sure the skin is compatible to your UNIT or model of fone. good luck...
Feb 20, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Where do you download sknis/themes for This cell phone.
WWW.ModMyMoto.com
You'll find here anything you need to modify your motorola phone.
You'll find there a program wich helps you install your skins in your phone.I think it's called "Skin manager" or something like that.Read carefully there on the site; it's very easy; I used to modify my Motorola z3 phone ;)
Aug 31, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
FREE UP MEMORY ON A Razor V3
/a/
DL_DB_INET_RECORDS - Gets rid of provider shop links
Scarlet.tcf - Icon for scarlet skin (dont delete if you want to keep this skin)
Silver.tcf - Icon for silver skin (dont delete if you want to keep this skin)
ss_scarlet)176x220~~ - more theme/skin graphics
wp_scarlet_176x220~~
Silver Skin Wallpaper 176x2~~
Silver Screen Saver 176x2~~
mib_op_greet
OICQBuddyDatabase - Assuming this has to do with IM (dont delete if you are going to use IM)
**Pretty much everything else in this folder needs to stay the way it is, I may have forgot some files, but basically everything that has to do with the IM and skins can go!... make sure that you DO NOT delete the moto theme skin stuff!!!**
/a/mobile/audio
Delete everything except:
funlight.pat
MyToneDB.db
TempToneDB.bd
six .bas files
**Leave Start~up.mp3 & Power~down.mp3 if you want them... I deleted these files as I dont care for Startup/Shutdown sounds**
/a/mobile/pictures
Delete Everything
/a/mobile/skins/Scarlet (If you want max space and dont care about skins)
Delete everything
/a/mobile/skins/Silver (If you want max space and dont care about skins)
Delete everything
/a/mobile/system
shutter1.amr
shutter2.amr
shutter3.amr
shutter4.amr
shutter5.amr
wvim.emoticons - for IM
wvim_emoticons_yahoo
**do not delete mma_ucp/mma_dcp (menu) files or the count_down files (or your timer for your camera will not work anymore)**
/a/mobile/wvim
Delete everything if you dont care about your IM
also these folders
/a/mobile/mib, /a/mobile/kjava.
Also using P2kmenueditor I removed the IM graphic from the main menu and replaced it with the motomixer from the multimedia section because I had an extra icon after enabling the Video Camera. There are probably a couple other files I forgot about that I deleted but this is the bulk of it, pretty much leave everything in the /a/ folder alone unless I said delete, I didnt touch the following directories /a/mobile/audio/vavr, /a/mobile/certs.
The files names on your phone will vary from the ones I have listed above because most people dont have the flex my phone came with but you get the idea of what you can and cannot delete.
Jun 14, 2008 | Motorola Mobility RAZR V3
ORiGInAl SKinS WerE DElEtED!!!
you need to have the mobile phone reflash.
May 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Theme intalation
sir
I cannot know the process to download
themes to my motorola VC3i razr
Pankaj
May 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
To download skins for motorola v3i
Hai dud, You can do it  1. Download P2K commander and its associated driver 2. Install it on your system and run it in tasjbar. 3. Then also download Skiman in which you can insert your favorite         skin,add pictures or delete,whatever! 4. After successfully installing P2K commander &  all  associated drivers connect ur mobile and click on Skiman it will pair ur cellphone. 5. In Skiman manager,Click on -->install-->(if any menu options come up then just click OK-->),directs u to a folder, select & click ur skin-->rest the software will do the job. 6. At last from "more"-->click on "Set as active",and restart ur mobile. 7. Tada....ur mobile is now with ur favorite skin.
Hope it helped u!
Feb 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Moto directory is missing
what you should do is have the phone reflash.....so take it to a mobile service center and have them do that for you.
Feb 20, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
