Question about Acer Aspire 1360 Notebook
Aspire web connections
I was wondering if there was any way to get the 1360 to go wireless as i have had no luck in spite of trying very hard?
  • holly202 Sep 25, 2008
    sorry but it is not coming up with a wireless network but i have the codes etc for it, but without the wireless network i am stuck. i have looked where you said and its not there. many thanks
The Aspire 1360 doesn't have Wifi built-in. You will need to buy a separate Cardbus (PCMCIA) or USB Wifi adaptor. I use an old Netgear Cardbus adaptor which seems fine.
Posted on Nov 09, 2008
    Genius:
  • 1,124 Answers
To go wireless:
1.- check if your wireless device is working
2.- If not you have to turn it on
3.- Select your wireless network (control panel>>network connections>>wireless networks)
4.- Connect to the network (is the network is pass protected you will prompt for a password)
If above doesn't help, please describe better your issue
Posted on Sep 25, 2008
Can't configure the network with ethernet cable
Hey, you're almost there. The connection between the no-wireless PC over ethernet to the DAP-1360 Repeater is fine. The reason it can't connect to your LAN or the internet, however, is that the repeater isn't actually repeating your Ofir network, it is instead creating it's own, completely isolated wireless network (Ofir_EXT).
The D-Link setup and documentation is confusing, and doesn't have proper instructions for the repeater setup.
Rerun the setup wizard, setup as a repeater, then select manual configuration method.
Now, enter the wireless network name of your the network you want to extend (in this case, Ofir). Then enter the same security and password etc. for Ofir in the following fields, just like you were connecting to Ofir from a smartphone or laptop.
Once that is finished, you should be up and running. If things worked, you should NOT see any new wireless network. There should be Ofir and just Ofir. Wireless repeaters work invisibly, you'll still connect to the same network like you always did, but now it will have much improved range thanks to the DAP-1360. The computer entherneted to it should be networked on the wireless LAN and have internet access after this as well.
Good luck, I hope my instructions were clear. Wifi networking is easy, it's understanding all the manufacturers less-than-intuitive software that makes it hard.
Oct 16, 2012 | D-LINK SYSTEMS DAP-1360 Wireless N Range...
Router can't detect DAP 1360 when installed about 90 meters away. UTP connectors tested okay.
have you tried turning on and off the router and AP? it would scan again...it looks like you just need to recheck connections and powers...
Oct 09, 2012 | D-Link DAP-1360 Wireless N Range Extender
My acer aspire 1360 wont turn on when i power up al;l i get is a black screen, the motherboard light flashes once and then goes off leaving only the power light on please help!!
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 22, 2010 | Acer Aspire 1360 Notebook
Aspire 1360 black display
the most common fault is the inverter which sits just behind the screen bezel if you are confident in taking things apart it is something you can do yourself check out this web site for help might not be the same laptop but principle is the same hope this helps
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Nov 26, 2009 | Acer Aspire 1360 Notebook
Can I install windows 98 on my acer aspire 1360? where do I get the drivers from?
Download the drivers from the Acer WEB site Make sure you select the model of your laptop and the Win98 version of the drivers Use this link to get to the Acer support: -
http://www.acersupport.com/notebook/index.html
Nov 21, 2009 | Acer Aspire 1360 Notebook
Hi i removed my hard drive out of my acer aspire 1360 laptop now nothin its blank its starts up but its like brain ded
yes you have to restart yor system again and make sure it boot from the hard drive. what the system need to run on is in the hard drive
Oct 27, 2009 | Acer Aspire 1360 Notebook
The bluetooth
tell him to download a new installer for windows vista visit this web site> (http://www.acer.com)> good luck to him and only you
Dec 15, 2008 | Acer Aspire 1360 Notebook
Acer aspire 1360
Offhand, it all depends on what other indicators or things that could be determined. Pls try:
  • determine if there is a beeping sound when you boot the laptop;
  • other than the power and charge indicators, any other lights? blinking perhaps?
  • after sufficient time that the unit has powered up, does pressing on the caps lock makes one of the led light up or close?
  • could you try re-seating the memory modules at the bottom behind a panel/lid?
  • could you try hooking it up to an external monitor and trying?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 06, 2008 | Acer Aspire 1360 Notebook
Acer aspire 1360
If the original hard drive was replaced in the laptop the cd that came with it will not work.
Mar 30, 2008 | Acer Aspire 1360 Notebook
Acer 1360 ..LCD is blank, I cannot see anything along no indicator for hard disk
hmmm check out your power connection. see is the adaptor giving power to your lap when you connect this to laptop. There might be an indicator at the jack point of laptop to your adaptor.
If the adoptor is not working well then try to use another one of same configuration.
Thanks
Iqbal
Mar 11, 2008 | Acer Aspire 1360 Notebook
Acer Aspire 1360 Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
