Question about Frigidaire FRS23R4A Side by Side Refrigerator
Fridge door dented
Fridge door got dented during move. can dents be knocked back out, from the inside via door removal, or do we have to replace door.
  • 1 more comment
  • N2KYAKING Sep 25, 2008
    I HAVE THE SAME PROBLEM . HELP... A $2000 FRIDGE WITH SUCH AN OBVIOUS DEFECT IS MAKING ME SICK!
  • candr Sep 26, 2008
    Thanks new door ordered
  • Anonymous Mar 22, 2014
    how to remove a dent from freezer door
    President:
  • 1,462 Answers
No - door is in two parts - inner and outer with foam between
Posted on Sep 25, 2008
How to remove dent from back door?
Mainly would depend on type of veh. and dent ,just bowl shape or creased line dent that wasn't here B4 so after inteior door panel removed and access to outside body skin is possible . This is where you could push dent using only soft material tools to back and to push with . If dent is bubble shape 5 - 10 inches you can puchase rubber suction puller or stronger glass transport suction tool and pull it out on exterior panel itself.
Paul Douglas
Apr 06, 2015 | Cars & Trucks
How to remove a side panel to fix a dent?
You can't. The body panel is made from a single sheet of metal.
Aug 05, 2014 | Danby DFF1144W Top Freezer Refrigerator
How do I repair a dent in the door of my stainless steel refrigerator?
if the dent is not creased; use a suctioncup dent puller availlible at any autoparts store
Feb 04, 2013 | LG LFX25960ST Stainless Steel French Door...
Rear passenger side got dent how do i replace it
Joko,
You are not very clear on exactly where the dent is. The area behind the side door is called a "quarter panel". These parts are not easily replaced, as they are a welded, structural member of the car's structure. Replacement requires specialized cutting and welding tools, normally only found in auto body shops. If the dent is not to bad, you could try removing the interior plastic trim panels and pushing outward to remove the dent.
Providing that the paint is not damaged and there is not an actual crease in the quarter panel [commonly referred to as a "pop" dent] I would suggest contacting a DENT WIZARD company. They will come to your house and fix the dent, using specialized tools and skills. Do a Google search for PAINTLESS DENT REPAIR including your geographic location in the search to find local companies who can do this work. It's much cheaper than taking the vehicle to an auto body shop.
Dec 11, 2011 | 2000 Nissan Quest
How do i get a dent 2 by 4 out of the fridge. there really isnt any scratchs but just a dent. can i some how get it out with out having to replace the hole stainless steel door
there arent any real solutions outside of some auto body repair shops have a suction cup dent puller that might help. most of these doors have a molded foam isulation inside that prevents you from getting to the inside of the door panel to push a dent out. even if you could it would be a rough job . you would have to remove the inner door liner including lots of screws, if the inner door liner isnt molded to the outer door panel. so unless you know someone that works in a body shop, the only real option is to replace the panel, which wont be cheap and i would suggest having a tech install it because if you damage it while installing it, that would be on you and the parts company probably wouldnt replace it for free. Good luck!
Dec 17, 2009 | LG LSC27950 Side by Side Refrigerator
All my power windows are working from the driver
the body shop may have removed the inside door panel to knock the dent out to do this you have to disconect the electric window conector block they might have forgot to reconect it .it is located behind the door panel
Nov 03, 2009 | 2003 Lexus ES 300
Dents in fridge door
Contact an automotive "paintless dent removal" provider-- they are mobile, so they can come to your home.
Jul 09, 2009 | LG LSC27950 Side by Side Refrigerator
DENTS IN CAR DOOR
You need a suction tool to remove the dents, here what it looks like.
Jun 21, 2009 | 1999 Daewoo Lanos
Dent in easy clean stainless steel fridge door
first off its not "stainless" its clean steal. and yes it does dent very easy! i found the only answer is to replace the panel or buy a new fridge .. i do NOT recommend clean steal to anyone. i have the same problem a very expensive fridge and i already have many dents in it also scratches. the lady "highly recommened this fridge for people who had kids" i guess i should have done my H.W
Apr 28, 2008 | Refrigerators
Frigidaire FRS23R4A Side by Side Refrigerator Logo
1,169 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
