Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Need an owners manual for a westell a80-750022-07 modem
  • Ap12
    Ap12 Dec 02, 2013
    Hi James King, I want to help you with your problem, but I need more information from you. It looks like Westell only makes as a90 in the Versalink 7500 product line. Can you confirm you have an a80?
3 Suggested Answers
SOURCE:
chexmix02
SOURCE: Connect 2 PCs to Westell 6100 DSL modem
JJ,
Yea, isn't that annoying!  Took me like 15 - 20 min to figure out you just leave it blank and click ok or apply whatever it is and you're golden.  I'll post seperate here for a full set of bridging instructions.
Posted on Oct 10, 2008
SOURCE: What Is The WEP For A Westell Modem, Model 7500 A90-750015-07
In order to get the WEP for a westell modem, first check the default gateway ipaddress of the modem. Connect the modem to the computer and check the def gateway.
Steps to check the def gateway.
Win XP: Start>Run>cmd>OK.
In command Prompt type ipconfig. Def gateway. You might find something like 192.168.1.1.
Type 192.168.1.1 in the address bar of your IE browser. You would get the westell modem page. Default username and password for the modem would be admin and password. If this does not work try admin and admin. Even if this does not work reset the modem. The default username and password would change to admin and password. But before you reset the password please make sure you have your ISP username and password. Once you get into the modem page click on wireless settings. You would find wireless status. In the list you would find 64 bit wep key. That is your WEP for westell modem.
Posted on May 02, 2009
Can't reconfigure my wi-fi wireless router with my computer
The manual is at:
http://www.pdfdocspace.com/docs/1343/westell-7500-manual.html
(a really stupid web page but I got the manual the first time).
The reset button is on the back between the power supply and the ethernet connectors. You press this and follow the prompts on-screen. You'll have to read the manual intro to see how to connect to the screens.
Sep 22, 2012 | Westell Wirespeed Westell 7500 Dsl Modem...
Westell model A90-750015-07 manual
I found something on amazon, take a look here: Amazon com westell a90 7500 manual. I hope this was helpful. cheers
Sep 12, 2012 | Westell Wirespeed Westell 7500 Dsl Modem...
Westell 6100 manual Rev R manual available?
http://www.google.co.ma/url?sa=t&rct=j&q=westell%206100%20manual%20filetype%3Apdf&source=web&cd=4&ved=0CDYQFjAD&url=http%3A%2F%2Fwww.westell.com%2Fdocs%2Fsupport-documents%2Fwestell_prolineg90_userguide3D214D374C48.pdf%3FStatus%3DMaster&ei=tFXETtfwLYe28QPW3uywCw&usg=AFQjCNFBjA31h8DNWEuubd9_WWF5vfyatA&sig2=5xF0buxf9K9YbLu51gRJCg&cad=rja
Oct 30, 2011 | Westell Wirespeed LiteLine 6100...
I have a Westel wirespeed. Can I hook up a
The Valet Plus manual shows rear connections for 4 wired computers (like most routers), so you would plug your work computer into one of those. The yellow Internet port on the back of the Valet would connect to the modem's Ethernet jack (also yellow, I believe; that's the standard color coding). If you need full setup information you can download the manual and get other answers at Cisco's site.
Apr 11, 2010 | Westell Wirespeed LiteLine 6110 Modem
Do i need a wireless router if i have westell 6100f
Yes. The Westell 6100f is not a wireless modem, therefore, you will need to get a wireless router to connect wireless computers.
Or if your ISP is Verizon and you want a wireless modem/router, you may contact them and replace the Westell 6100f with a Westell Versalink 327w, or Westell 7500, or an Actiontec.
Hope this helps!
Mar 01, 2010 | Westell Wirespeed LiteLine 6000 Modem
Setup Wireless Router to Westell 6100 modem
Your Wireless router should have come with a CD. Insert the CD into your computer and follow it step by step. If it did not come with it here is a basic wiring setup.
From wall jack to Westell modem, From modem to uplink port on Max G router.
Reboot Westell modem. T
Everything should auto-configure unless you need a username and password for your DLS. If so you will need to program this into your router.
Dec 21, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Computer does not recognize my westell modem thru usb
yes.. you may do that and also, please make sure that the drivers of the USB ports on your computers are installed..
Dec 09, 2008 | Westell Wirespeed LiteLine 6100...
Westell 6100 network cable
I cant find the gui address to the westell wirespeed e90-610030-06 ?????
Jul 19, 2008 | Westell Wirespeed LiteLine 6100...
Driver
not true...i have this exact modem, and it is not plug & play, im searching for the usb driver myself and having no luck
Feb 28, 2008 | Westell Wirespeed LiteLine 6100...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
622 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Fred Steinberg
Fred Steinberg
Level 1 Expert
paul shaw
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
