Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
WASHER IS 4 YRS OLD. LEAVES PERMANENT YELLOW BROWN STAINS. LOOKS MORE LIKE A GREASE STAIN.
  • 2 more comments
  • Anonymous Sep 26, 2008
    Same problem and am sure it is greese comming from inside the washmachine.
  • shanhas Sep 27, 2008
    Leaves yellow brown stains on light colors. I believe it is rust stains from drum (or tub- not sure what to call it - from the interior tub area) where enamel has chipped off. Have touched up with appliance paint and briefly solved before, but has now returned. I think rusting is now leaking from the exterior side of the tub.
    I really don't think there is a permanent solution other than to replace the interior tub - I looked in to this the last time and remember it being quite expensive.
  • Anonymous Dec 25, 2008
    We, too, get blotchy, grease-like, stains. This has ruined a number of shirts, to the point where we question whether or not we should continue using the washer.  Frustrating.
  • Anonymous Mar 15, 2014
    bottom of stator cover is brown. Looks like grease/oil not rust.
    Novelist:
    Champion:
  • 261 Answers
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Posted on Oct 06, 2008
I have a Whirlpool front loading duet washer. It's probably around 10 years old... Not sure. But it leaves marks on my light colored clothes and has from early on. I just didn't realize the problem was the...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Stains on clothes
Check the fit of the agitator to the bottom of the drum. After this many years, it may have warped up to make a gap. Run a rag around the joint to see if it marks.
Apr 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
Hello gigiknoll
Welcome to Fixya
My name is Huum,
This model should be electronic ignition and does not use a pilot light.
The igniter may be faulty.or the gas module may be faulty.
Pilots are a thing of the past!
This requires a tech to test it with equipment.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
574 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
