Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw husqvarna Hi, the problem is that the chain don't move, kindo stuck... What do I do? Thanks
  • buddieemma Oct 19, 2008
    chain locks up as soon as I start cutting
My chain does not want to turn when i give it gas. the chain brake is not on and nothing is cloged in the saw. i noticed that it made a funny noice like something was broken what might this be?
Posted on Nov 08, 2008
As simple as this problem probably is, start with the simple stuff. Check the handle chain brake. Is it in the lock position? Then take the chain clutch cover off and check the contact area of the chain and clutch. Is it plugged with debris? If so clean it and check the chain tension.
Posted on Oct 12, 2008
Do be a ******,take the damn thing apart and look at it. it does not take a rocket scientist to figure it out.
Posted on Oct 06, 2008
  • 45 Answers
Make sure the chain-brake is not on.
Take off the bar & chain & clean it. While they are off, check the sprocket is free to turn.
Check the bar is not pinched on the chain.
Posted on Sep 27, 2008
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
Husqvarna 450 rancher chainsaw locked
Did you try and pull back the chain lock shield. its the handle abouve the bar, if you hit it it will lock the chain. Pull it back
Nov 20, 2012 | Husqvarna Garden
I have a Husqvarna 136 / 141 model chainsaw - it has been idle for several months. After starting and allowing to warm up for a minute or two and then attempting to use it - when applying full throtle the...
Has the chain stuck to the bar.? Chain oil has a tendancy to turn to a gluey state when say for some time. Is the chain brake fully releasing.?
Aug 29, 2011 | Husqvarna Garden
How to check for proper chain tension husqvana 450e
You should be able to move the chain with your hands, but not too easily. Please wear gloves when doing this. Also, if you pull the chain away from the bar at the middle of the bar, there should be no more than 1/8" between the bar and chain.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Husqvarna 450 e-series 18" Chain Saw
After a few months in storage, my saw will start, but the chain seems stuck - I can['t move it with my fingers, and when I gas up the engine, the chain doesn't move & the engine stalls. There's no...
Release the chain tension adjuster and push the bar inward to make sure it moves. This is an auto-set tension adjustment and should set itself so that the chain can be be moved by hand. The chain oil on the bar may have gelled enough to prevent chain movement. A spray of WD-40 around the chain perrimeter would probably loosen the chain as well. Hope this helps!
Aug 15, 2010 | Husqvarna 450 e-series 18" Chain Saw
While cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain will not move freely. When hitting gas will
Did anyone explain how a chain brake works?
Pull the forward most handle as far aft as possible. It should click if it was tripped. Wearing gloves can you easily rotate the chain?
Remove the clutch cover. If it seems stuck the chain brake is tripped do not force it off, reset the brake. Inspect all interior parts for small twigs or pieces of tree that have jammed the brake or clutch. Anything beyond this please see the dealer that sold it to you. HTH
Lou
Oct 24, 2009 | Husqvarna Garden
How do you loosen the chain on a chainsaw husqvarna 136?
Hi there. On the outer bar cover near the motor you will find 2 nuts. Slightly loosen those two nuts. Then check around the these nuts or near where the bar attaches to the powerrhead at the front of the saw. You should find an adjustment screw of some sort, which will be the chain tensioning screw (which moves the bar forward/back depending on which way it is turned). This has the effect of either tightening or loosening the chain, so turn this screw noting whether the chain is tightening or becoming loose.
You must slightly undo those 2 main nuts on the side of the chain/bar cover first or the bar will not move and the chain cannot be loosened.
Jul 08, 2009 | Husqvarna Garden
Husqvarna 345 chainsaw chain doesn't move freely and heats up
has the chain ever came off the saw?and i'm going to assume that it is the correct chain for the saw...reason i ask about the chain comming off the saw is that when it does the driver have a tendency to become nicked and will heat up the clutch because the saw is trying to drive the chain links through the chain slot.also you need to look at the drive sprocket to see if there is any wear on the teeth....also over tighting the chain will cause the clutch to heat up.
Feb 22, 2009 | Husqvarna Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
332 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
