Question about Lexmark Office Equipment & Supplies
I have a Lexmark 5700 printer that I need to reboot. The problem is I can not find the two discs that I nned to do this. Ihave the 2 discs that are for Windows NT 4.0, but I need the 2 discs that are for Windows 3.5. Can you help?
    Novelist:
  • 170 Answers
Found your drivers for 3.5 but you'll have to go to drivers and downloads and follow the step by step process to down load them, hope this helps and if it does, please mark as a fixya!! Click Here!!
Posted on Sep 25, 2008
I cannot use the scan function on my X5470--specifically, to scan documents into PDF format. "Cannot retrieve Application List" is the messge shown. How do I repair this function?
Make sure the Lexmark OCR scan software is installed on your computer. The software allows you to scan your documents to PDF file. The software is only available on the installation disc that came with your Lexmark printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
I am trying to scan documents with my Lexmark X4530 It says "cannot retrieve application list". How do I scan with this issue?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Wait until your computer fully recognizes the USB connection. Try to scan again.
Note: If you're scanning documents for editing, make sure the Lexmark OCR scan software is installed on your computer. The scan software is available only on the installation disc that came with your Lexmark printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Aug 11, 2011 | Lexmark X5470 All-In-One InkJet Printer
I nned help in getting my printer on to my computer as i have lost the instruction on a disc thank you
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Jun 25, 2011 | Lexmark Office Equipment & Supplies
I can not scan documents with Lexmark 2500 Series via Windows
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect the printer from your computer. Reboot your pc. Unplug the re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Also, make sure the Lexmark OCR scan software is installed on your computer. The scan software is available only on the install disc. Insert the cd in your hard drive to install the software. If you lost the disc, please contact Lexmark technical support for additional assistance.
Jun 17, 2011 | Lexmark X2500 All-In-One Printer
Unable to scan, however it does copy??
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Follow the simple steps below:
  1. Disconnect your printer from your computer.
  2. Reboot your computer.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, reconnect it into your computer.
  5. Try to scan again.
You can also re-install or update your Lexmark X2670 printer driver by visiting the Lexmark website at http://bit.ly/hTPEL5. Also, if you are scanning a document for editing, make sure to install the Lexmark OCR scan software. The scan software can only be installed using the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 01, 2011 | Lexmark X2670 All-In-One Printer
Cannot use Lexmark X4850 printer without installation disc.
You should be able to go to the lexmark.com web site and search for your printer. Go to downloads and enter your printer description or X4850. This is the result I got. If your computer is running Windows, then you need to get either the download for 32 bit or 64 bit software. See microsoft.com link to tell the difference.
http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_US&question=X4850&productCode=LEXMARK_X4850&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X4850&searchid=1257295870088#2( Lexmark Link for Macintosh or Windows Driver Software)
http://support.microsoft.com/kb/827218 (To tell if your Windows Operating System is 32 or 64 bit)
Nov 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark, as all major manufacturers, has the installation CD content in downloadable form on their website.
Nov 03, 2009 | Office Equipment & Supplies
Cant find disc to install printer to computer lexmark x8350
Go to the Lexmark website. Click on the support link; lookup your specific model # and select the operating system you are running. The software/drivers will be listed for free download. Download, install, and reboot and you should be all set. Hope this helps.
Aug 26, 2009 | Lexmark Inkjet Z517 Photo Printer
Lexmark X3430
yes you can you can go to the website http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X3430 and select your operating system on your computer and your done
Dec 15, 2007 | Lexmark X340n All-In-One Laser Printer
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
