Question about Salton MEEX20B Espresso Machine
SEAL ON TOP
THE SEAL ON THE EXPRESSO SIDE WHERE YOU PUT IN THE WATER DOES NOT WORK ANYMORE AND WE NEED TO BUY A NEW ONE, BUT DON'T KNOW WHERE TO PURCHASE IT.
  • cybermama Sep 28, 2008
    steam is coming out of the top where the water goes in and not coming out of the milkĀ frothierĀ
  • Anonymous Dec 12, 2008
    seal is split on mine too cant find a new one anywhere
Try to go back from where you got it from and tell them what happen maybe they can give u another piece or tell u where to go.
Posted on Sep 25, 2008
Dr Tech Me - 710 leaks water. Needs white seal?
I have the exact same problem, I need a new seal but can't find one for the life of me.
One thing I do know is this machine gets rebranded under a lot of names (Pronto ME-710, Merol ME-710) I haven't had any sucess finding replacement part yet, but looking under those names may help... If anyone finds anything please let me know.
Feb 28, 2013 | dr. Tech Commercial Grade Fully Automatic...
We just had a new RO Unit installed at our sink, and a line run to our Maytag fridge. The water filter is inside, at the top. We don't really need the filter anymore, as the RO water is more tha
Take the filter to the hardware store and get the necessary fittings (and maybe a short piece of tubing) to connect the in and out lines without the filter. Perhaps easier deal is a new filter which should NEVER become clogged on RO water.
Aug 02, 2017 | Maytag MSD2734GE Side by Side Refrigerator
I have the Krups 964 espresso maker; it is about 10 years old. Recently it began to pour water out and around the coffee basket holder at a fast pace, and it does not make expresso. I did remove the...
I don't know much about this unit, but there might be a rubber seal in head where the porta filter locks in to. It is possible that this seal is either damaged or just corrupted with grounds. Try cleaning it out and or checking the seal for damage.
Sep 10, 2011 | Coffee Makers & Espresso Machines
I have two 50pn 2.4s pumps on my system. One was tripping the internal overload. I shut it off and removed the pump to my work bench. Obvious by spinning the impeller that there was a bad bearing, but I...
Hi Don,
Thank you for your great explanation,
This pump really need some serious maintenance, this was cause because the mechanical seal broke down or was completely wear, check your warranty you have 2 years,
The overload jump because the pump at a motor failure, due to water,
The only way to repair this pump is to take the motor and rotor visually check if there is any burn spot or damage part if not you can try to make everything dry for a few days, replace the defect part and put it back together it might work (30%)
But if you think the electric motor run to long with water in it, It will be more worthed to replace it with a new one,
And i stongly suggest you to check the oil on your other pump, to know how is your mechanical seal,
To check the oil its the only star screw on the side of it, when you remove it try not to spill to much out, if the oil is completely clear your mecanical seal is fine, if its white like milk you need to replace it, it mean water start to infiltrate, and its worthed replacing it,
Hope i could help you let me know if you have more question,
Have a great day,
(mechanical seal is what prevent and block water to reach the electrical motor, its the part that as a big stainless steel spring with to sillicon face on top and bottom,)
Sep 11, 2010 | Tsurumi Pump s Submersible Trash Pump -...
Our Dishwasher is leaking out the sides bottom sides.
The door of every dishwasher has a compressive rubber seal. When you close the door, it compresses to prevent the water lealking out. Yours has perished and a split is allowing the water to leak out. You just need to write down the model and serial number (for good measure) and contact the makers parts supplier. Buy the new seal and install. If you are not confident to try this yourself, a repairman can be booked to do it for you, but it's not difficult, the seal slides into a guide track (at the top internal centre of the door) - the track continues down to the base of the door, across the base, up the other side and when installing, you simply inch it into the guide around the door perimeter until it joins again at the top.
A bit like putting a belt through belt loops...
Apr 07, 2010 | Weber Genesis Silver C Premium Grill
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water leaking through the seals on my 93 mx5, what
buy and install new seals ar try and see if window is adustablie
Sep 07, 2009 | 1993 Mazda MX-5
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
Dishwasher spray arm.
There is no lubricant or adhesive that you need to put down. However if you removed that seal around the motor shaft you will need to replace it with a new one. Once that seal is broken it won't sit right again. When you buy a new dishwasher motor or heater it comes with that seal new cause it won't go back on again right. Dishwashers are a real pain to work on, they have so many little parts and so many picky parts that it just makes them a pain to work with. What ever you do just never buy yourself a Bosh. The way they built those, they can only be worked on by taking the entire machine apart to the floor. Let me know if you have any other questions. I'm here to help.
Jan 23, 2009 | Maytag MDB6650A Built-in Dishwasher
Krups XP2070
if the water is leaking from the back left side of the unit then the seal/valve to the expresso water container is lose and leaking. you can either go the warranty route or open the back up and tighten the two screws holding the seat/valve in place.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Salton MEEX20B Espresso Machine Logo
50 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
