Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv will not turn on manually or with remote
My mitsubishi HD 1080 will not turn on, when manually turned on 2 seconds green light goes off
You need to get the stk chips replaced. i had it done with mine, it cost me 411 dollars for a tech to come do it. it worked fine for about 4 months now, and my red color is gone. mitsubishi sucks, sorry : (
Posted on Sep 27, 2008
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
Every time I turn my HD 1080 series Mitsubishi on 2 1/2 seconds later it turns off by itself
ok, a model number would be helpful but:
when set turns off and green power light goes out: on the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and let both go.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
This is the error code and indicates where the problem may be---let me know what code you find and I will tell you what it means.
SD TECH
Apr 28, 2012 | Televison & Video
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
It won't turn on and we don't have a remote control. What can we do ? Mitsubishi Medallion HD 1080
not knowing model number I will suggest a few things: if green power light comes on for a few seconds and goes out:
On front of set press and hold both the Menu and Input (device) buttons at same time for at least 5 seconds and release both.
Power light should blink a two digit error code like 2 blinks,,2 blinks,, a pause and repeat it several times.
This is a error code that indicates what area problem is in, let me know what error code you find and I will tell you what it means----if set has been unplugged you will have to try to turn it on and let it fail before you go for the error code.
SD TECH
Mar 31, 2011 | Mitsubishi Televison & Video
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Mitsubishi HD TV 1080 blinking green light
sounds like it has a bad DM assy, or a bad 9v reg ic.
the dm can be repaired, there are 4 capacitors on it that need to be replaced.
Dec 13, 2007 | Televison & Video
Mitsubishi WS-65809 65" Rear Projection Television Logo
305 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
