Question about Sanyo Televison & Video
I have a sanyo vc-h813 vcr that won't power on. The digital display shows a inconsistent flashing or flickering of 4 dashes ( ---- ). I press the power button nothing happens. The flickering changes speeds, but there are some rare times the flickering slows down and becomes consistent and that's when I attempt to press the power button again and it powers up like normal. I open it up to see if the fuse in power line was burnt out, but looks like new, and use compressed air and cleaned any dusty components. Can you help diagnose this problem? Or did this vcr just burned out?
techman
  • 3130 Answers
SOURCE: NO POWER, Yes blown fuse.
Was this the 220 ohm in the power supply??? and if the 5 amp blew right away then it probably took out the bridge rectifyer with the power surge that comes alog with hurricane damage to the power lines as I used to live in florida and repaired lots of sets damaged from storms!! After you check the bridge rectifyers I would start looking to find any other shorts. First measure across the ac line with the fuse replaced but not plugedf in . If its shorted check what I mentioned before if its good after you replace the shorted parts you maybe in luck. need more assistance go to sams photo facts download a schematic and we will trouble shoot this together if you post it here so i can look at it. good luck
Posted on May 02, 2006
SOURCE: Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Posted on Oct 22, 2008
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
Damilare
  • 358 Answers
SOURCE: LG x110 laptop power supply problem:
To be very sure of what the problem is, try to test the your laptop with a another friend's battery, or through a technician first. If it powers, then try and test the laptop again with another AC Adapter, from someone who uses the same type, or a technician.
Trying out these two things will give you a clearer and better idea of what might have gone wrong.
Hope it helps you out.
Posted on Jul 13, 2009
SD Tech
  • 14553 Answers
SOURCE: Press power button just clicks, no power. Found
The best thing to do here that is easy-----get at the two STK-392-110 CHIPS and un-solder both of them--if the set then comes on--one is bad--you might also take a close look at all the low value resistors around them--all have location numbers on the top of the board--like RK51 etc.
If you find a discolored resistor--or if unsoldering the chips lets the set turn on----you have found your problem.
Let me know if you have questions or need help--I am here to help people.
SD TECH
Posted on Oct 23, 2009
Need code 4 one 4 all tv remote contorol 4 Sanyo?
Hello
Three digit universal remote codes for Sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 13, 2011 | Televison & Video
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
Four digit universal remote code for Sanyo are:
Direct Code Entry
OK.
Jan 25, 2011 | Televison & Video
Would you happen to know the 3 digit manufacture code for a Sharp VC-H992U Video Cassette Recorder? I need this info to input it into my TV so that the VCR will work with the TV. The TV provider is Dish...
Hello! Here is the link to our remote codes, if that fails follow these additional steps for the Power Scan this should resolve it as well.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
***BEFORE STARTING THIS USE THE INSTRUCTIONS IN THE LINK TO PROGRAM THE REMOTE TO 222
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
  2. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
  3. Press and release the Power button.
  4. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
  5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  6. To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Dec 23, 2010 | Sharp VC-H992U VCR
GE 5-Device Learning Remote i need the code for my sanyo tv so i can reprogram it
You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
Oct 23, 2010 | Televison & Video
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
How do i add channels to me sharp vcr h813
Press the preset button and search button.
Mar 09, 2010 | Sharp VC-H813U S-VHS VCR
Need the right code for my sharp vcr vc-h810
The codes to use for a Sharp VCR and a URC-3021 are 0048 or 0807.
To setup your URC-3021 for the VCR, these are the steps:
1. Turn on your VCR .
2. On the remote control, press VCR once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off.
Hope that helps.
Oct 24, 2009 | One For All URC-3021 Remote Control
Tuning Sanyo VCR
Press both channel buttons simultaineously for 3 seconds it will automatically tune your programmes press ok when ok flashes on vcr screen display
Nov 04, 2007 | Sanyo DS27910 27" TV
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Can't get picture to display on ch 4
there is a switch at the back that you can to channel 4 or 3 good luck
Apr 17, 2007 | Sanyo VWM-950 VHS VCR
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
