Question about Mitsubishi WS-55807 TV
WS55807 Hi, I am having the same exact problem with my Mitsibishi WS55807 and was wondering if you ever fixed the issue and if so what was the problem. I am reluctant to spend hundreds of dollars to fix this since the set is almost 8 years old, thanks.... ecomparoto@comcast.net
  • ec3de Oct 02, 2008
    Thanks for the information, I just ordered the fuses and I will buy osme acetone as suggested.One question I have is do I need to solder the fuses into the board do they plug in? Thanks again.
  • ec3de Oct 11, 2008
    I was able to clean the board with acetone as suggetsed and I now have the picture back, I did not replace the fuses as I am still waiting for them to arrive. Even though I have the picture I do not have any sound which started the problem before I loss the picture, any suggestions to help resolve the sound problem ? Thank you for your help, you advice has been great, many thanks again.
  • 927 Answers
Good Day;
Yes, there is a TRICK of removal of centerboard. Remove back cover, after disconnecting the POWER CORD, remove 2/3 screws from black chassis frame, on back bottom, release wire restraints, look for two clips on front of black chassis. Can see easier if you remove speaker grill and small panel. Remove all golden type screws from PCB. Replace IC’s STK392-570 (2).
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Posted on Sep 28, 2008
52" Mitsubishi projection TV has stripes
Depends on exact model number; if a WD-52525 or something very similar pitch it---they are falling apart and have all kinds of troubles.
Google the full model number with "problems" to see what issues the set has like a hundred bad surface mounted caps etc.
Apr 23, 2012 | Televison & Video
I have got sound but no picture on 2 relisys rtl1720
Hi, I have the same brand tv only 32" but exactly the same issue with sound & no picture. I was just wondering if you ever resolved this??? Thanks
Mike
Oct 05, 2009 | Relisys RTL1720 17 in. LCD Television
The flash won't fire, and the pilot light won't come on. I've tried new batteries, and that doesn't work. The little LCD screen does have power. I'm wondering if I blew the strobe. Thanks!
Hey i have a 430ex mk1 which when turned on did not fire and red pilot light did not show , i have had the flash since 2006,
i have also tired new batterys and the LCD Light works and the Txt shows up,
did you work out the problem and also how to fix it?
thanks
rick
email
psnp@hotmail.co.uk
Oct 05, 2009 | Canon Speedlite 430EX TTL Flash
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
Need help with same prob you had with tv
Have you been able to fix this yet? I'm having the same issue..
Mar 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi ws55807
I had this problem and corrected it by resoldering all 36 pins of the 2 convergence IC's. Biggest problem was getting the circuit board out far enough to prop it up and get underneath and get at the solder connections, required unplugging a few cables, 3 screws holding it in. Works great now, I used to fix it by taking the back off and banging on the Heat Sinks which house the IC's, I could tell then that it reacted like cold solder joints. I decided after a field service guy charged us 95.00 for a service call and quoted 650.00 for a repair. Hope this helps someone.
Nov 05, 2007 | Mitsubishi WS-55807 TV
Mitsubishi ws 55807 have the blinking lights problem and not powering on
Yes on some sets are a bit differant depending on the model number there is still a DM board. The disassembly is a bit different and the service manual will describe how to take apart the TV set to get to the DM board. The repair is the same for the DM board. I am sorry but I do not have the the service manual but one can be downloaded here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=WS55807 Good Luck
Jun 20, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55807 "Bow-Tie" Problem
If your not a tech, its highly advisable to not even open the set because of the high voltage and x-ray radiation issues. Now if your a technician ,you gonna need to get a service manual, Look up the convergence circuit, Find the two or three convergence driver ics, find the b+ feed resistors to those ic, and order the exact replacement parts. if you dont replace all at once, and with exact replacements, you will be in the same boat a few months down the road. This is not a repair a handi-person should consider doing as even if you get the ics replaced, your gonna need to do some minor or could be major convergence alighnment and your gonna need a cross hatch generator to do this. This repair should cost ya about 300 to 400 bucks? Sorry man Good Luck
Jun 14, 2006 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
