This could be the fan relay or a fault in the fan unit. The fan relay is located in the power distribution box under the hood. To isolate if its the relay or the fans, start the vehicle and turn your AC on to Max cool. The fans should kick on. If the fans don't start running when you turn the AC on replace the fan relay. If they do then shut everything off and start checking your wires going to the fan looking for breaks or spots where they may be grounding out.
Odds are your fan relay is out. I take your model has two fans with seperate eletric motors.
