LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
norbert sroga Posted on Nov 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door removal need to replace inlet valve. Door removal would make the job easier so how do I do it ? thanks.
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Nov 06, 2011
Anonymous
Expert
Level 2:
Answers
489
Questions
0
Helped
299282
Points
854
Open the door and remove the 6 screws that holds the metal door panel. The panel will drop down and you should be able to get to the water valve without having to remove the whole door.
Hope this helps.
Ice maker that fills will water dispensed through refrigerator door.
the valve is probably operated by a celenoid, if you removed it during the hose replacement it may be installed incorrectly, out of line or not have a good ground.
GE dishwasher inlet valve leaking
see this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Started leaking out of top of sink thing, now so bad, ran down sink inside cabne
If your dishwasher is Leaking check the following
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel andadjust switch until properly aligned.
Door Hinges
Apr 02, 2013 • Dishwashers
My dishwasher leaks.
follow the steps and fix it God bless you
Door Seal
Dispenser Seal
Water Inlet Valve
Door Latch
Door Hinges
2helpful
Leak at bottom of door
see this causes and use the common sense. God bless you
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
Dispenser Seal
Water Inlet Valve
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Water is not coming out of water dispenser
Hi and welcome to FixYa,
There are 40 models under this main grouping: KSRG25FK I had to pick one....
KSRG25FKT05 as an example:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504906
Listen for the micro switch item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504906&diagram_id=28177830#d28177830
You should hear a click as you actuate the water dispensor arm. (no click = bad switch)
Note also that the freezer door must be closed. Check the freezer door switch item 25 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504906&diagram_id=28179767#d28179767 The light should go off when the plunger is depressed. If the light says on with the plunger depressed the switch has failed.
FYI you would have no ice in door if this switch has failed. If the ice in door works and there is only a water in door problem disregard this step.
Last open the fiberboard cover in the back of the unit and locate the inlet water valve. If you can do a swap of the 2 solenoid connectors between the 2 solenoids. Then use the water in door actuator. If you get water to the icemaker with the freezer door light switch plunger depressed you have a failed water in door solenoid on the inlet water valve. The water inlet valve is NOT repairable.
This is a KIT for replacing the inlet water valve:
http://www.appliancepartspros.com/part_details.aspx?part_id=3160649
You can find the valve cheaper without the kit parts if you shop around.
This is a Job Aid that will show you how to open the dispenser area if you need to.
http://applianceassistant.com/pdf/inDoorIceSystem.pdf Also good for ice maker and water in door troubleshooting.
Thanks for choosing FixYa,
Kelly
Leaks on left side bottom of door
Hi
Thanks for using FixYa. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. You should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
1helpful
Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Turn on dishwasher hear noise but no water comes in
Hi..
If the dishwasher is noisy you need to follow this;
  • Check the spray arm for damage and obstructions
  • Check the inlet filter screens
  • Test the water inlet valve
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow.
inletvalve.jpgThere are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
  • Check the motor and mounts
  • Check the fan motor and blade
  • Check the drain for obstructions
Good luck! Thanks of using fixya.
Regards
PCmania
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
