Question about Mitsubishi WD-52725 52". Rear Projection HDTV
How to reset hours (4000) after replacing lamp
I repalced the lamp in my tv (wd-52725). I was told to reset the lamp hours through the TV setup menu but I can't find this option in TV setup. The lamp indicator light on the front of the TV is still on.
  • Mitsubishi Master
  • 8,617 Answers
When you replace the lamp as soon as you power up the set it should automatically bring up the menu asking if you have replaced the lamp and would you like to resett the lamp hrs. Your problem is not with the lamp. its most likely the power pwb capacitors. You can get the repair kit at the following link with instructions.
http://servicemanuals.vstore.ca/
Posted on Sep 25, 2008
Replace tv lamp but the replacement light is still on how do I turn it off
Hello
Reset the lamp hours through the TV setup menu each time you replace the lamp cartridge. Otherwise,
the lamp warning message will reappear sooner than necessary.
After you change the lamp cartridge, you must reset the lamp
reminder through the TV Setup menu
Go to the setup menu, there you can see the reset proceedings with illustration. OK.
May 12, 2011 | Mitsubishi WD-52526 LCD TV
How to replace lamp
1. Turn the tv off and unplug it. 2. carefully access the back of the tv. 3. when facing the back of the tv on the lower left hand side there is a cover held on by two phillips screws remove this cover. 4. After cover is removed you can see the lamp which is also held in by two phillips screws, these screws only loosen and do not completely remove from the lamp. 5. after loosening the screws there is a handle in the center of the lamp, take the lamp by the handle and remove it from the tv. 6. reverse this process to install lamp.
I hope this helps you. After you replace your lamp make sure you reset the hours for your lamp. Press tv menu, select the setup menu, and then select the lamp reminder option to reset hours to zero.
Nov 17, 2010 | Mitsubishi WD-62528 62 in. LCD Television
Reset lamp timer once lamp is replaced? from user manual for instructions-with no cost.
1. Press tv menu on remote 2. Select the setup menu 3. Select the lamp reminder option to reset the hours to zero
Nov 14, 2010 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Sep 18, 2008 | Mitsubishi Diamond WD-65831 65" Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
WD-52725
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
414 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
