Question about Smeg 18 in. DWI410 Built-in Dishwasher
Smeg SA620X Dishwasher
Dishwasher powder does not release during wash cycle and dishes not cleaned properly
  • 1462 Answers
SOURCE: Powder not dispersing
possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Posted on Jun 21, 2007
SOURCE: Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Posted on Feb 10, 2007
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Dishes not clean after they go through the washing cycle
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Jan 24, 2011 | KitchenAid Dishwashers
Spots are left on the dishes after washing. Dishes don't look clean
Hi
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Powder detergent does not dispense into the dishwasher during wash cycle. The powder gets wet and stay in the dispenser and then when the drying cycle comes on it dries the powder and it becomes hard in...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 09, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishes not cleaned
When ever I hear of a dishwasher "suddenly" not cleaning properly, with spots on the glassware and soap not dissolving:
-If the spots are white patches, you can suspect the DW detergent powder. Go buy a name brand of detergent powder and I bet you will see a dramatic improvement. You may need to run a cycle or two with white vinegar added (up to two cups added after the DW starts, fills and begins to wash.)
-If the spots are a film / slime, you should suspect that the heating element. For the dW to be effective cleaning and rinsing clear,the DW needs to raise the water temp during the ~wash~ cycle (after the detergent dispenser has magically opened. After the heating element has been replaced, you will see an immediate improvement.
-If you had reported food debris sticking to dishes, (which you didn't), the first thing to do is clear the holes in the wash arms, then open the sump area , remove the filter assembly and inspect closely with a flashlight to locate blocking debris. (watch out for broken glass!) Inspect the impeller and make sure it is not damaged. If after assembly, the cleaning is still poor, it is time to replace the wash pump / motor assembly.
Good Luck! Ask more questions as needed!
Mar 30, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Open Questions:
See all Smeg 18 in. DWI410 Built-in Dishwasher Questions
Smeg 18 in. DWI410 Built-in Dishwasher Logo
229 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
