Question about Samsung Televison & Video
Dvd/vcr recorder error message ec:0507 cut off the power and restart
SOURCE: Emmerson DVD/VCR EWR20V5
if yoy dont hav firm ware up date you cant fix the machine. the machine if working will on work on 4x. like i said if the machine is not working you maybe able to fix it with the firm ware up date that lets it record on 8x only, now if some of the people out ther has the firm wade update disk, they could shareit with all the people who dont, i had one but its been 2 years sence i used it, i will look for it and make it available for all
Posted on Sep 14, 2007
  • 30 Answers
SOURCE: DVD RECORDER KEEPS ON REJECT DVD,SHOW ERROR DETECTION DVD-RW
try another disc that you know works it prob does not read that type of dvd
Posted on Jun 12, 2009
roybro123
  • 3 Answers
SOURCE: Will not come on
RCA DRC8320N DVD Recorder/VCR
Symptoms:
Seems to have no power, no lights on front lit, if listened to closely one may hear a "click click click" sound.
Solution: Replace C232 on power supply board.
Additional technical info:
In this design, the switching power supply feedback is from the 5 volt standby rail only, which is odd. The problem is caused when C232, the first filter capacitor in this rail and the sampling point for the feedback circuit, opens. The clicking sound is transformer rattle as the power supply restarts repeatedly.
Posted on Nov 19, 2009
  • 102 Answers
SOURCE: I have an error message U81. The DVD recorder
These are error codes generated by the main microprocessor which are tripped by corruption, preventing it's operation and which requires the processor to be reset.
The codes do not actually mean anything at all because the corruption error potentially has a great many possible causes.
It does not point to any specific fault as such.
U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter' but I dare say if Panasonic told you that , you would be no further forward.
Corruption can arise for many different reasons .. and is not surprising in a box that has an aerial feeding endless streams of complex data into it, has a mains connection with interference on it, has two internal data storage and retrieval systems, either of which can be problematic... and sits permanently bathed in electrical and radio frequency fields of varying intensity.
Causes can be difficult to identify and may be internal or external.
Such problems may be exacerbated during the transitional phase of the DSO [ Digital Switch Over ]
In practice, all one can do is follow good practices:
Don't stack gear - or give it plenty ventilation if you do.
Ensure good clean mains supplies.
Ensure a properly installed aerial system with sound connectors and adequate screening.... etc.
Posted on Feb 05, 2010
SOURCE: SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Posted on Feb 09, 2010
I'm try execute copy from tape to dvd I'm got Error [EC:203] and [EC:207] Help me please Thank you BR michael
Model number is everything. Samsung mostly supports DVD-R, DVD-RW, and DVD-RAM. Don't confuse this with plus (+) formats, although since @ 2004 other manufacturers are using Sony's multi-format DVD recording format. Are the codes in your user's manual? If not, try downloading a service manual for free from sites like Elektrotanya, Hifimanuals, hifiengine, or eserviceinfo. Then you may determine if you service help.
Jun 19, 2016 | Samsung DVD-VR320 DVD Recorder/VCR
What does EC 0507 System Error is found mean?Thanks
this means that the laser carriage did not return to home , Id try unplugging and turning power back on to see if it helps to reset this fault
Jan 19, 2016 | Samsung DVD-VR320 DVD Recorder/VCR
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
Cannot record on DVD-RW disc
Somtimes if you change brands of dvds will help!
Dec 13, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD/VCR Emerson
Okay have had the same problem for 6 months, have bought 10 different brands and speeds of DVDs. Tried the reset idea, 5 times still no luck! I was so furstrated I was just going to buy me a new player.
Then I seen a laser lens cleaner, it was under $10 dollars at Wal mart. Came home reset the played 1st then tried the cleaning disc. I"M recording AGAIN and no error messages!
dukie 1558
Jan 22, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
Nov 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Televison & Video Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
