Toshiba 32" Model 32A10 chassis TAC 0019 Turns on but no picture. Sometimes picture OK, but goes dark after a short time.
4 Suggested Answers
MrBob84
  • 90 Answers
SOURCE: johnnyhotrodcamaro@yahoo.com
Mit has screens that are second to none, if you can't find an official Tosh one. It might need to be cut to size, but no biggie -
Mr Bob
Posted on Feb 03, 2008
  • 70 Answers
SOURCE: Toshiba television, rear projection, HDTV.
this is a convergence problem not a reset problem. go into the video menu and look for manual convergence. you could try auto convergence if your tv has it but i think you will have to go in and manually do it. just line the colours insync with the white bars and this will clean up the colours on your entire screen let me know if this doesnt work but im pretty confidant it will
Posted on Sep 21, 2008
  • 59 Answers
SOURCE: model:46wt510, turns on, got sound, very dark picture shuts down
five blinks on this unit indicates a weak or out crt tube you can try opening the unit and very gently tapping the bottom of the glass part of the tube to see if you can clear some of the carbon build up from the tube only a temporary fix. be very careful not to break the tube
Posted on Jan 25, 2010
SOURCE: Model:46wt510, turns on, got sound, very dark
it will need a new light board or you will need to turn the brightnees up
Posted on Aug 03, 2010
Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 15, 2008 | Televison & Video
DARK PICTURE
Just restart the tv and can u tell me company name and model no.........
Aug 03, 2008 | Toshiba 42H83 42" Rear Projection...
Model:46wt510, turns on, got sound, very dark picture shuts down
Jan 25, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Dark Picture after being on a short time
You should clean the pins on the end of the picture tubes. Use a piece of sand paper or emory cloth as the pins are probably tarnished.
Aug 08, 2009 | Televison & Video
I have a JVC LT-32x38 that turns on and displays an image for a second but then goes blank and outputs sounds only.
Sometimes the picture goes out but the screen is still lit(backlight on), if totally dark like TV was turned off then check voltages in the power supply board(24v, 12v, 5v) if all ok replace the inverter.
May 27, 2009 | Televison & Video
Red & Blue lines on screen
stk392-110 i think mine was made in 2002 and i also had to replace mine
Oct 26, 2008 | Toshiba 50H72 50" Rear Projection...
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
Johnnyhotrodcamaro@yahoo.com
Mr Bob
Jan 11, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
