Question about Pioneer AVIC-N2 Car DVD Player
Problem turning unit on
The unit just testing it out before hooking everything up, does not turn on. The flashing red security light is there so it is getting power, but the unit fails to turn on. What might be the cause of this? First thought I came to was a bad wiring harness so I connected a different harness into it for a Pioneer and tapped it into the factory harness. Any help would be greatly appreciated.
Thanks !!
  • bogeycentral Sep 25, 2008
    I found out that I have to have more than just the unit connected. Once the navigation brain was connected its golden.
  • 30 Answers
Have u got both powers correct. u only need 1 to get security light on
Posted on Sep 25, 2008
My pioneer avic n2 will not turn on,but when the
sounds like you have blown your acc fuse or your risistor on your red wire on your radio has shorted out you can bypass this wire by choping it off it dose not affect the radio ,dvd at all.
Jan 17, 2010 | Pioneer AVIC-N2 Car DVD Player
Wont power up!
HI
what do you mean you can't change the source from tuner to DVD? or you mean the changing of function!? can you give me the exact information trouble to your unit!? thanks...
Dec 02, 2007 | Pioneer AVH-P7480DVD Car DVD Player
Turns on but nothing displays.
it sound like the memory wire is hook up wrong, check the yellow wire first then the red wire if still the same problem, connect the red and the yellow wire together to see if it come on it should come on you might have to run a hot wire from the battery in the dash then hook the yellow wire to it so your memory stays on
Apr 11, 2009 | Dual XDVD8170 Car DVD Player
Scource button is red but unit doesn't seam to have power?
your red ignition wire is not getting 12 volts. that is why the cd player will not turn on. to test your voltage either buy a voltage tester or take it some where to have them hook it up and test it
Feb 24, 2009 | Jensen VM9510 Car DVD Player
Screen doesnt turn on
try selecting the dvd or tv modes ... if that doesn't help , reset the system and start all over.
Nov 10, 2008 | Jensen VM9510 Car DVD Player
UNIT IS NO WORKING
The yellow wire is constant 12 volts and is used to maintain radio station presets, clock, and tone settings when the car is turned off. To use the stereo, you need the red wire hooked up to switched power (so that it's got power when the key is turned, and the power shuts down when you shut off the car). That's the one that'll give you "power" to the head unit.
Aug 25, 2008 | Clarion VRX935VD Car DVD Player
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Security code light blinking nodisplay on lcd
If you have not already tried resetting unit. Bottom left of unit you should see a small round reset button. Press this small Reset button with a Pen or other pointy object. If this does not work refer to trouble shooting section of Owners manual to see if any of that info may help.
http://service.us.panasonic.com/OPERMANPDF/CQVD6503U-MULTI.PDF
If you need service manual I may be able to help kstahl65@att.net
Jan 17, 2008 | Panasonic CQ-VD6503U Car DVD Player
How to test unit without hooking up to vehicle.
You can connect the + and - from the stereo to a 12 volt DC power supply, or a step down transformer to test out the functionality.
Best of Luck.
Oct 24, 2007 | Jensen VM9510 Car DVD Player
Security Code enabled
try thr reset button on the front lower left hand corner
Sep 15, 2007 | Panasonic CQ-VD6503U Car DVD Player
Pioneer AVIC-N2 Car DVD Player Logo
374 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
