Question about Kenmore 57022 Side by Side Refrigerator
Icemaker Does Not Deliver Ice to the Dispenser
After 2 years of good service, I found no ice in the dispenser of my side by side Kenmore model 5702. The icemaker is the top of the freezer and dispenser is in the door. I confirmed the red light for the icemaker switch, which is the side panel of the freezer, was on. I also tugged on the rotating arms. Something happened and one set of cubes was delivered to the dispenser. I thought it was solved. Not so. Next day...turned the switch off then back on, tugged on the arms. Something happened and 2 sets of cubes were delivered. It appears water is getting to the icemaker and cubes are being frozen. Something is preventing the automatic rotation to move the cubes from the maker to the dispenser. Suggestions.
5 Suggested Answers
  • 473 Answers
SOURCE: Ice is not ejecting
Sounds like the icemaker thermostat is opening too soon which turns the heater off.  The easiest thing to do is replace the whole ice maker which I have seen pretty cheap on ebay.  If you want you can test these part with an ohm meter.  Check the heater for resistance.  If it is ok then replace the module and thermostat.
Posted on Oct 26, 2007
SOURCE: I have a Kenmore side-by-side, model 253 54364405.
washerwill not spin
Posted on Feb 18, 2010
  • 266 Answers
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Posted on Aug 15, 2010
  • 32 Answers
SOURCE: My icemaker won't deliver cubes despite switching from crushed to cubes on selector, what's a guy to do
you have to take apart the complete ice maker from inside the freezer as it has to be cleaned on a regular basis to operate properly. check with your owners manual, it tells you how to clean it.the ice cube shoot is the first to freeze up & block your flow of ice. it's not hard to do. all the best.
Posted on Dec 01, 2011
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
May 01, 2011 | Refrigerators
Kenmore side by side model #515541 01--replaced water filter -water dispenser works great but no water coming into ice maker - what could be problem? we purchased this used-is there something we have to do...
I had the same problem. Sometimes the tray overfills and freezes in the little line that fills the ice cube tray.
I solved the problem by taking an ice pick and clearing the ice from the end of that little waterline until the water started flowing again.
Feb 10, 2011 | Kenmore 57029 Side by Side Refrigerator
Mold on Ice dispenser
If there is mold on the outside of the ice dispenser you should wipe it down periodically/ weekly or more often with a mild mixture of soapy water with a touch of bleach in it. Make sure that nothing in the refrigerator is blocking the port that ice is deliver through or that ice is not building up around the inside of it. And do not let water or ice lay stagnant in the door tray at the bottom of the dispenser.
Good Luck and God Bless
Aug 21, 2010 | Kenmore 53642 / 53644 Side by Side...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Not getting water to icemaker;Water dispenser on door still working.Icemaker will go through process of dumping ice.No water leaks found.
3 steps: #1, check the fill tube for ice blockage,If not blocked- #2, verify there is power applied to the water valve when the IM cycles. #3 If yes replace the valve, If no replace switch in IM(complete faceplate in some models). Limited possibilities so elimination of what is working will locate the failure.
Dec 07, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker
Hi, it sounds like made the inlet tube to the icemaker is frozen up. First thing to check tho is that the water valve to the icemaker is ok. If you take the water line off of the icemaker valve, you should be able to blow through it. If you cannot blew through the inlet line that leads to the icemaker tube, it is plugged with ice. You cn thaw that tube out woth a hair dryer.
If I can help further, please let me know.
May 11, 2009 | Refrigerators
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 57022 Side by Side Refrigerator Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
