Question about Panasonic DMR-E85H DVD Recorder
I own a panasonic dmr-e85hp
When its plug in i hav no power to unit can u help
  • 3 more comments
  • Charles Rawlinson Sep 25, 2008
    its not the fuse what know
    one of ur experts told me to check the fuse when i plug it in before i got nothin no power so still have no power and its plug in what next
    i open it up and the power supply is not damaged and i have plug it into another outlet still has no power
    it is very live and flowin with juice
    its not the power cord
I just fixed my unit. Remove the hard drive cage and look at the circuit board underneath. Look carefully at the capacitors - if you see any brown residue on top of the capacitors or they appear to be bulging they've failed. On my unit all four 680 uF caps were bad. I bought replacement parts from www.mcm.com (make sure you get the 16V, low ESR variety). Replacing all four of these bulging caps brought my unit back to life.
Removing the board to swap these out isn't difficult - just take your time and make sure you get all the connectors unplugged. Re-connect electrically before re-testing - these "chopper" type power supplies can self destruct of not tied to a load of some sort.
Posted on Jan 30, 2009
    Scholar:
  • 148 Answers
TRY TO CHECK ALL THE POSSIBLE CONNECTIONS THAT MAY CAUSE THIS PROBLEM. IF YOU ALREADY CHECK THE PSUPPLY AND THE FUSES, AND ALSO CHECK THE OUTLET IF IT HAS A POWER AND ALSO THE POWER CORD.
SECOND IS TRY TO CHECK THE PSUPPLY TRANSFORMER AND RESISTOR. THIS CAN BE POSSIBLE IF YOUR UNIT NEVER GENERATE A POWER INTO THE MAIN BOARD.
Posted on Sep 25, 2008
  • 10,594 Answers
Symptoms shows its failure of Power Transformer. You need to replace it.
Transformer part number and price is as follows..
G4D2A0000179 TRANSFORMER 9.32
Its available at Panasonice Parts
Good luck.
  • Shahid Electronics
    Shahid Electronics Sep 25, 2008
    Or you can buy Power Supply at Panasonic Parts with part number as follows..
    VEP01950B
    POWER SUPPLY PCB
    73.09
  • 4,234 Answers
These units use a switch mode power supply. These are not the easiest to repair, but tend to have some fairly common faults. The most common are the following 2:
1) The main transistor attached to the heatsink is shorted. This usually causes the main fuse to blow, so I don;t think that this is your problem.
2) These power supplioes require oscillation and on the primary side of the supply, you should see 2 capacitors with a voltage rating in the 200V range. One will be 80-200Ufd and the other will be in the 22ufd range. Try changing the 22ufd cap. This is the "kicker" that starts the oscillation. This is a common failure part.
If neither of the above resolve the problem, please update this and I'll try to give you a few more options.
Dan
    Guru:
  • 1,894 Answers
You got only two options
either no supply from plug point.-- confirm it by plugging the unit in another point.
else damaged power board- confirm it by opening the unit from back side. power board can be found the the place where the power cord enters
  • 1 more comment
  • dewan nafees ahmed Sep 25, 2008
    dont you see any components of the power board damaged?? please take a meter and check if any of the components are dead in the power board
    what do you mean by "it is very live and flowin with juice""???
    if its not power cord it must be some component in the power board which is dead and not allowing power to enter in.
    few cases they are visible easily by burns or bulges.
    few cases they just die with out leaving any clues.
    on those case you can only get them out by checking each and every component.
    Guru:
  • 558 Answers
Thanks for posting in FixYa.
May I know since when this problem arised.
Please check the cable and adapter if connected any, also check the connector of the DVD recorder.
Let me know if this works.
Regards
Ellin
  • Panasonic Master
  • 13,433 Answers
Possibly a bown fuse. Please check that first, got warranty on it?
Panasonic dmr-es40v
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
Jul 08, 2016 | Panasonic DMR-ES40VS DVD Recorder/VCR
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-e85 locked up. I finally got it to
To setup your IR Blaster (transmitter), hold down the channel up and down button at the same time on you the unit for more than 5 second until the unit says bye and 12:00 flashes, then power on unit and the setup screen will come on your TV.
Sep 15, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85Hp dvd won't turn on now.
The power supply board on the DMR-E85H has problems. The earlier boards suffered from leaking capacitors and the later boards from voltage regulator problems. If your machine is now dead, the fuse on the power supply board has also blown.Go to the following links for details and photos on how to fix:Replacing capacitors:http://www.fixya.com/support/t216825-dvd_recorder_frozen_please_wait_displayReplacing the voltage regulator:http://www.rbjtech.net/electrical/e85/e85.htm#0Hope this helps. My machine had the later ps board and the voltage regulator replacement worked perfectly.
May 26, 2009 | Panasonic DMR-E85H DVD Recorder
U61
According to the owners manual the U61 error is listed below. (Page 47)
There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
You can download the owners manual here.
http://service.us.panasonic.com/OPERMANPDF/DMRES25-MULTI.PDF
I would recommend trying to unplug the unit overnight and then plug it in and see if this helps. Not sure what you might have tried, but this may help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If not then please comment to this post and I will try to help you further.
May 10, 2009 | Panasonic DMR-ES25 DVD Recorder
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
PANASONIC DVD RECORDER DMR-E85HP
Check caps on P/S C1270 and C1271 if puffy replace with {2} 1000uf 35vdc and you should be fine.
Jan 12, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
Remote
When I have the same issue with my dmr-ez37v I recover by unplugging the unit for about 15 seconds, then plugging it back in. It seems the unit get "hung" about once a month and requires a hard power reset.
Regards,
Bob Headrick
May 19, 2008 | Panasonic DMR-EZ37VS
Panasonic DMR-E50 no power
Check the two pin power plug on the back panel.
These units have a common problem on the power board where a regulator overheats and finally blows. Sometimes even before it blows it will take out an internal fuse. If the power board is faulty the repair is easy for an engineer and not too expensive.
Mar 19, 2008 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
579 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
