Question about Sony Cyber-Shot DSC-V1 Digital Camera
File numbers not displayed on screen
When the camera is switched on the screen does not display the numbers of each photo which we need to identify each picture.
    Brigadier General:
  • 3,006 Answers
This may be a very simple problem.
Set the function dial to playback (the box with an arrow inside).
Adjacent to the top right of the LCD screen is a button with a graphic next to it of a box with two vertical lines either side. Each time you press it it alters the amount of onscreen display information and it can also turn off the screen to save battery life The latter is useless in playback mode, but very useful when taking photos if you always use the optical viewfinder as I do.
Posted on Jul 02, 2009
I was coping my pictures on to my computer and while it was doing so i noticed that the downloading froze and displayed that it will be complete in 8hrs so i did a booboo and hit the cancel button but now...
Try going to "Search" on your computer. On Windows PC computers, you can usually find it on the lower left of your screen. Enter the word "Found" or "Found file", and the photo file should appear. If that doesn't work, go the folder on your computer that contains the most recent photos that you have successfully downloaded to the computer. Go to the last photo you downloaded, and copy that file number. Enter that entire number in the "search" window, and change the last couple of numbers in the file to something a few numbers higher. In other words, if your most recent photo on your computer from that camera is something like "DSC05300", change it to "DSC5310", and do a search for that number. If your recent photos are in the "found" file as the message told you, that "fake" number should match one of the photos you're looking for. If it appears in the search, it will show where that photo is located, and all your other "lost" photos will be in the same place. Good luck!
Jul 22, 2014 | Dane Elec EyeFi Pro X2 8GB Class 6 SDHC...
Why does a photo display with a wrong date in Lumix Simple Viewer
Once the photo is date stamped that is a done deal no changing it.
Jul 28, 2017 | Panasonic Lumix DMC-FZ18K Digital Camera
Went to a camera class a couple of months ago to learn how to use my Nikon D3000. We made a lot of setting changes. Now when I download photos, I get 2 copies -- a jpeg and an nef file. Do I really need...
In some ways the NEF file is the equivalent of a negative, while the JPG file is the equivalent of a print from a negative. However, since digital copies are exact, you don't need the NEF file if you're not going to do anything fancy with the photos. I know people are going to argue with that --- heck, I'm one of them, I shoot only NEFs.
Press the info button to display the information display, then press the i button to put the cursor in the information display. Use the multiselector to highlight the current image quality setting (the topmost item on the right side of the display) and press OK. Select JPG fine and press OK.
For full details, see the "Image Quality and Size" section in the manual (page 50 in my copy).
Jan 05, 2011 | Nikon D3000 Digital Camera
My memory card is completely empty, all photos
You need to reset the file-numbering.
Turn mode-dial to Set and turn on the camera. Select Frame No. from the setup menu. Switch Frame No. to Renew. Press OK. Format the card (also from the Setup Menu) After formatting, select Frame No. againg and switch to Cont. File numbers will now start from 100.0001 again
May 10, 2010 | Fuji FinePix S7000 Digital Camera
Importing Images
The CR2 suffix means that the picture was taken in the RAW file format, a proprietary format. This requires that the images be processed by a software conversion to be 'readable' by the computer. The EOS Utility software that came with the camera will work, as well as a number of third-party software packages. GOOGLE "raw file conversion Canon digital rebel" to see the options.
The other option is to take your photos in JPEG format (not RAW). Your computer can 'read' any JPEG format image.
Feb 28, 2010 | Canon Digital Rebel / EOS-300D Digital...
Purchased camera in March and working great until yesterday. Took a batch of pictures yesterday but was not able to download most of them to my computer. Got computer message "there are no images in the...
Sounds like you're switching the same card between cameras. Rule #1...one card per camera. Format the card in the camera it is to be used in. There is no Rule #2.
Aug 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Viewing photos without time and date
Unfortunately the Nikon Coolpix 7900 does not have a 'display' button to take care of this. So you need to go through Menu to access Setup menu. Here you will get option to customize the display.
Feb 09, 2009 | Nikon Coolpix 7900 Digital Camera
PHOTOS CANNOT BE DISPLAYED FOR PRINTING
check the supported image size and file extension of the photo. it is possible that you got a larger orientation on the size of your photo.
let me know
Sep 10, 2008 | Kodak EasyShare 12.0-Megapixel Digital...
Cant display or delete photos from Polaroid digital camera
Need more information. What kind of camera is it and what is the model number. When I get this info, maybe I will be able to help you.
Mar 27, 2008 | Cameras
Sony Cyber-Shot DSC-V1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
