Question about Gestetner Copier
Part I need a bypass tray for a Gestetner 3222. Can you get one? If so, how much?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Check with They carry Gestetner Parts. It's a Ricoh machine so you can order it that way.
Error sc420
Posted on Jan 17, 2009
  • Gestetner Master
  • 2,794 Answers
Use Ricoh equivalent af220 or af270 when ordering.
Posted on Sep 26, 2008
Fuser code reset
i do not know what machine you wait to reset the fuser code and the service code it has S.C but to enter the servie mode you press (star-107-#) then mode enter then check where scrol you find where its says error reset
Jul 12, 2014 | Gestetner 2 Pack 3222, 3227, P7027, P7032,...
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
It always jam in the bypass when feeding long even though the print is already out of the fusing unit.
is the paper size correct? example bypass paper size is 8 1/2 x 13 or 8 1/2 x 14for long size. setting this to your bypass tray will tell the machine that the paper on your bypass is long.
Aug 24, 2011 | Gestetner DSm618d Copier
We've loaded a new ink cartridge, but the printer doesn't recognize it. The model is a 3222
You have a very old machine...
Assuming that you are putting the right bottle... It could be several problems.
Faulty clutch.. faulty toner supply unit... faulty drum Unit...
The best advise i could give to you is to call a technician...
See you
May 04, 2011 | Gestetner Copier
How much is gestetner 3222 worth
This machine is made by Ricoh and the same as a model Aficio 220. Pretty old and not worth much. If it runs and makes nice copies then $300 to $400. If it does not work or makes poor copies then next to nothing. I specialize in buying/selling used refurbished copiers and am very familiar with this model.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Office Equipment & Supplies
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
Only prints half the page
Well, I'm back to suggest another solution or 2.
After my previous solutions didn't take (we have to start with the most basic solutions, especially when i can't see the results), let's try something else.
At this point it sounds to me like a laser (optical) problem or blockage.
LIft the green handle inside the front cover as if to replace the toner bottle, and underneath you should see the end of a small peice of glass protruding. CAREFULLY slide this out. My suspicion is that there will be a film of toner, or dust built up (particularly on one end of it). Clean it with a soft tissue and slide it back in.
If this glass is not present, but you see the slot, then it has been removed, and I would then suggest that the toner/dust has carried all the way into the laser unit, and the assembly will need to be removed and cleaned -this is not something for the end user to perform.
Regardless of whether or not this solution fixes the problem, you will have arrived at a place where a technician will be required, because it has been narraoweed down to either a Drum (photoconductor) problem, transfer assembly problem, or perhaps a laser positioning problem....but I do hope it helps.
May 22, 2009 | Gestetner Copier
Copier Only prints half the page
Sounds to me that the paper tray is set incorrectly. There is a dial on the back of the machine that needs to be set correctly once the paper tray guides are adjusted accordingly -particularly when running 8 1/2 x 11" (letter) size paper. It can be set to run either lengthwise, or laterally (portrait) make sure the dial is set to the proper setting on ALL trays. If the tray is set for lateral, for example, and the paper is installed lengthwise, the scanner only utilizes 8 1/2" in length rather than the full 11". Frequent jamming is also a common problem when making multiple copies, because the paper is not where the machine "expects" it to be. Also check that the LCD display reads the proper size / orientation after adjustment.
Hope this helps. Please rate solution :)
May 21, 2009 | Gestetner Copier
Printing Problem - Help
n your computer, left click on START, left click on CONTROL PANEL, then left click on PRINTERS. On the PRINTERS SCREEN, RIGHT CLICK on GESTETNER icon. On the drop down menu, left click on PROPERTIES. Left click on ACCESSORIES tab. On the paper source setting, select TRAY 1 LETTER as the default paper source, left click on UPDATE, then APPLY, then OK.
May 08, 2008 | Gestetner Copier
Gestetner 3222
When you put a new cartridge in I take it you have removed the black cap that sits on top of the toner bottle (if you haven't remove it) The machine as default allows a 15 second gap from when you open the door and put the cartridge in to when you close the door. If you are too fast at changing toner open the door wait 15-20 seconds then close the door . Machine will then show on the control panel that toner is loading. If this does not work repeat two more times if still does not work then the drum unit (Photo Conductor Unit) is not accepting toner you will have to replace it.
Hope this works
Dec 22, 2007 | Gestetner Copier
76 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
