Question about Dishwashers
Maytag Quiet Series 300 dishwasher, dishes are dirty, control panel only works some of the time, bad smell coming from dishes and dishwasher.
  • 3 more comments
  • Anonymous Sep 30, 2008
    YES! I have the exact same problems! Constatly contacting Maytag customer service is a joke...they DENY that they've had any problems ONLY me. Yeah right, as I see other complaints about the same thing I guess I'm not the only ******!
    Front panel doesn't turn on sometimes. The glasses come out with some nasty gritty particles inside of them.
  • tinaperez1 Nov 16, 2008
    control panel lights not working, dishes not clean, dishwasher is loud.
  • dboggs58 Nov 18, 2008
    My control panel lights have slowly gone out one or two options at a time. Now all are out and the only display that sometimes comes on is the "2HR" So I really only have one wash option, when that light choses to come on. I also have the "awful smell" problem. This is the first dishwasher I have ever owned with this smell problem. Did you ever get your working properly?
  • Anonymous Apr 06, 2009
    I have the exact same control panel and foul smell problems you are experiencing. Unfortunately I do have a solution.
    Same problem. No solution found yet. I have had nothing but problems with all new Maytag appliances. Never again!
Our control panel is fine. For now. (The machine is only 3 months old). This is our problem--and I haven't yet seen this complaint at all over the internt: The lower wash arm is getting stuck on the bottom rack and stopping immediately. This seems to be a design flaw. The bottom rack is just built too low. A service man was out once. He tightened the wash arm. Didn't work. The service department at the dealership is now ignoring our subsequent calls!! So I wonder if the "not cleaning" problem you have is because of this.
Posted on Apr 05, 2009
Maytag dishwasher legacy quiet series 300 clean light stays on after cycle is over
That light will remain on until you remove the dishes that are in there so that you know what is inside is clean and not dirty.
Jul 04, 2017 | Maytag Dishwashers
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
I have a maytag dishwasher model # mdbtt70awb quiet series 300 when you push any of the wash cycle buttons nothing works. the only button that lights up is heated dry so there is at least power there....
I had the same issue try hitting delay 1hr and start the 1hr was solid not flashing and an hr later it's running just fine. Think I need a new control panel but for now this is working.
Sep 04, 2010 | Maytag Dishwashers
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag Quiet Series 300 Dishwasher will not turn off after it com
Apr 05, 2009 | Dishwashers
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
782 people viewed this question
Top Dishwashers Experts
