Question about Electronics - Others
Rewiring a travel trailer
I have an old travel trailer I bought to restore. the wiring inside is gone and I am not sure about the black and white. there only seems to be a white wire left. any schmatics on this?
  • 102 Answers
You need to first decide what all you want inside as far as electrical features such as lights, outlets, fridge, stove , tv etc.. decide their locations then calculate the load it will pull and design the electrical circuits. Sound tough but it's not that bad
Posted on Dec 04, 2008
Rewire a three-way switch that was wired knob and tube?
I can help u with this but will need to b able to walk u thru it,
Feb 26, 2015 | Electrical Supplies
I need reconnect the wires to my truck i just bought it and went to hook up my trailer and noticed that the wires were all pulled out of the trailer connector and the bracket was bent i've got a big...
here's the way i do it,buy or if you have,a wire tester,get a good grounded on the tester,turn the left blinker on,touch the tester to the wires to you find the right on,mark as you go the wires,white is ground,black w/red and black w/white is turn
Jan 08, 2011 | Ford F-150 Cars & Trucks
Instructions for wiring a moving trailer connector
Trailer Wiring Diagrams 4 Way Systems
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4%20way%20wiring.jpg 4way_vehicle.jpg 4 way tow vehicle side.
4way_trailer.jpg 4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5way_vehicle.jpg 5 way tow vehicle side.
5way_trailer.jpg 5 way trailer side.
6 Way System, Rectangle Plug 3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6way_rectangle_1.jpg 6 way tow vehicle side.
6way_rectangle_2.jpg 6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6way_vehicle.jpg 6 way tow vehicle side.
6way_trailer.jpg 6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7way_vehicle.jpg 7 way RV flat blade tow vehicle side.
7way_trailer.jpg 7 way RV flat blade trailer side.
Jan 01, 2011 | 2001 Pontiac Montana
I have a Coleman Versa utility trailer. It's about 30 years old and the wiring is frayed, causing problems. I cannot find any info. re: a wiring diagram from Coleman or anywhere else. Do you know if one...
I rewired my versa trailer several years ago. Go to any place that sells the 4 wire strand trailer wire and get about 40 feet. It is a bit tedious but about a 2 to 3 hour job.
If you run across someone that wants sell their trailer, please let me know. The top on mine is very hail damaged.
Sep 07, 2010 | Electronics - Others
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Jun 05, 2010 | Kenwood Car Audio & Video
I am trying to wire a travel trailer that is 30 yrs old. I have red, white, black, brown, yellow & green wires. I have a 4 color pig tail off of the suv. how do I get the lights to work
Red is brakes
brown is clearance lights
yellow is right turn
Green is left turn
White SHOULD BE GROUND but may not be
you will need to test and determine if white or black is ground
The four wires coming from your SUV are clearance right, left and ground
Dec 27, 2009 | 2003 Saturn VUE
I have an early 90's Starcraft pop up camper. I just went to hook it up to the van and the travel lights (running, brakes, directionals) don't work at all. All lights worked when the camper was stored last...
When you say that you have power up to the camper, do you mean power through the pigtail/wiring harness with the tow vehicle connected?
The trailer harness wiring is the only way to power these exterior camper lights, i.e., through your vehicle. There are no fuses within the trailer for the exterior lights. These lights are only fused from the tow vehicle's fuse box. So either the connections in the trailer harness are open, or they're open at the tow vehicle connection.
Do the turn signals work on the tow vehicle? If yes, then the only other thing to check is the turn signal flasher in your tow vehicle. A heavy duty flasher is recommended.
From the trailer, yellow, white, brown, red, green, is connected to your vehicle backup, ground (frame), right turn signal, left turn signal, running lights, respectively.
The trailer's blue wire is for an electric brake connection to your vehicle.
The trailer's small black wire should connect to the vehicle's hot, 12V lead for the interior lights. The large black wire at the trailer hitch is for charging an RV battery on your trailer, if it's supplied with one. Of all of these wires, only the large, 12 gauge, black wire goes to the 25 amp converter, which is fused, for the inside lights of the camper.
I hope this helps.
Apr 25, 2009 | Sport & Outdoor - Others
How do you rewire a trailer
Are you putting on a 4 wire flat connector? Trailer Wiring
4 Flat Small
Brown = Tail Lights
Green = Right Turn Signal & Brake Light
White = Ground
Yellow = Left Turn Signal & Brake Light
Feb 01, 2009 | 1995 Ford Escort
Travel Trailer wiring, lights and electronic brake control
i have a 1996 chevy 1500 bought a brake controler but what wire do i put the blue wire to ther are 4 white wires from brake peddle that go on when peddle is pressed on.
May 27, 2008 | 1996 Chevrolet K1500
Replacement shelves
Yes you can get a replacement for the shelves, at a hardware store or somewhere else. Or you can try spray painting the spots there are rust.
Mar 29, 2008 | Sanyo HF-5020
Electronics - Others Logo
958 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
