Question about HP Pavilion dv6000z Notebook
DV6000 - NO DISPLAY
DEAR JAYBEE, I HAVE THE SAME PROBLEM CAN YOU PLEASE TELL ME HOW TO LOACATE THE CMOS BATTERY.
THANK YOU.
MICHAEL
Hello, sorry for a very late replay... if your unit is out of warranty there's no use of returning it to your dealer or manufacturer co'z they definitely charge you plus your time to spend in doing so.
locating the cmos battery is not that hard if you have the manual, anyway if you dont have it... there are only few covers at the back of the unit, you need a small philips screwdriver to open it, if you are not familiar with what cmos battery looks like.. it is a rounded metallic looks like a botton (same as the battery of your calculator.) if you found it, it is detachable.. carefully remove it as much as possible using your fingernail only. hang for several minute then place it back exactly before you removed it. good luck!
Posted on Sep 29, 2008
  • 65 Answers
Dont try to open the laptop.. let a service guy from the manufacturer do it
Posted on Sep 27, 2008
Cmos jumper
You would need to take apart the laptop in order to access it.
Before doing any of this, please make sure the battery and ac adapter is disconnected.
If you are lucky it would be just a small cutout for the memory/HDD section, there should be small battery connected via a wire to the board, simply pull it out for 30 seconds and put it back in.
See this article
http://www.cesgeekbook.com/2009/11/hp-dv6000-disassembly-tear-down.html
Mar 29, 2014 | HP Pavilion dv6809wm Notebook
What can i do Intel DG31PR motherboard no display
Hi
you can remove the battery, and replace the CMOS-Jumper to the next pin
do that for a minute, and put the battery back, the jumper to it's original pins
Plug-in the power, and start testing again.
Please tell us your results
Good Luck
May 13, 2011 | Intel DG31PR Motherboard
Can you please tell me where the Cmos battery is located and if there are any special techniques that need to be employed to successfully remove and replace it? It is (was) a DV6000 series laptop with a...
Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
1. Remove the memory module compartment cover
2. Disconnect the RTC battery cable 1 from the system board.
3. Remove the RTC battery
The RTC battery is secured to the computer by double-sided tape.
Reverse the above procedure to install the RTC battery.
Sep 12, 2010 | HP Pavilion dv6000z Notebook
Hi, how can I reset the cmos bios of my dv6000?
one of two ways to go about this, one is to restore defaults through BIOS it self or simply remove the CMOS battery from the motherboard, it looks like a large watch battery, about the size of a quarter, and a bit thicker
Feb 04, 2010 | HP Pavilion dv1000 Notebook
Urgent help needed to locate cmos battery laptopasus x51r series
The cmos battery is on the motherboard and unless you are competent at disassembling laptops then I suggest you take it to a repair shop for battery replacement.
Jun 09, 2009 | Acer Aspire 3690-2196 Notebook
Forgot password
hI,
You need to reset your bios, this will erase all your cmos data, incluiding your password. You nned to locate and remove cmos battery, in this model you will find the battery below your laptop, you nned to remove your back doors, locate your battery wich it is connected thru a little white conenctor to your Mobo, disconect, turn on your laptop, press f10 and this will go to your bios, remove all pass word in your security menu, turn off your laptop and reconnect your cmos battery, you will need to setup your dates corrctly.
This will resolve your issue
Please leave me feedback at fixya
supprt@vcrtech.com
vcrtech@hotmail.com
Apr 27, 2009 | HP Pavilion dv9000z Notebook
CMOS Battery location on samsung vm8000
cmos battery is underneath. Take off fan cover. remove fan screws x 4. Then lift black cloth on right hand side. You will see the offender. Lift the battery from the left hand side gently with a small flat head screw driver....
Dec 10, 2008 | Samsung Computers & Internet
Cmos battery?
Computer CMOS information CMOS is an on-board semiconductor chip powered by a CMOS battery inside IBM compatible computers that stores information such as the system time
How to replace the CMOS battery. Information about why time may be lost or decreasing rapidly and how to replace your computer cmos battery
Computer Battery Help The first type of battery is the backup battery, which is commonly referred to as the "CMOS battery".
Good Luck, Please dont for get to Vote/Thank You
Dec 19, 2007 | HP Pavilion N3390 Notebook
Hp pavillion dv6000 laptop
try removing batt for 10 mins then boot again. hope it works
Dec 01, 2007 | HP Pavilion dv1000 Notebook
Laptop won't power up
if u can reach the laptop main board there is a jumper near the cmos battery try to clear cmos by changing the jumper to the other position for some seconds (while power is off) so smos is clear.
Nov 11, 2007 | IBM ThinkPad T41 Notebook
HP Pavilion dv6000z Notebook Logo
820 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
