Question about Black & Decker Spacemaker 10-Cup Coffee Maker
My B&D spacesaver under-counter coffee maker is not perking the water. Running vinegar thru it does not solve the problem. How to repair it.
    New Friend:
  • 47 Answers
Check out this solution.
Posted on Jul 10, 2010
I am not able to get any coffee through the coffee dispenser. It just fills the overfill tray and leaks from under the machine onto the counter. Any idea what the cause is and how it can be resolved?
Try running a mixture of 1/4 cup Apple cider vinegar in a pot of water then flush with pots of cold water until no more vinegar odor. This immediately breaks through hard water scale buildup. You may also have a bad seal if it is leaking. You can get a repair kit from Mr. Coffee or if you have a Bunn, they have lifetime guarantee. You can return for repair, or request repair kit by contacting them
Jan 23, 2015 | Coffee Makers & Espresso Machines
How do you descale a bosch coffee maker
Run vinegar thru the coffee maker to remove hard water scale. Make sure you rinse the coffee maker well afterwards by running regular water through it so that your coffee does not taste like vinegar.
Jul 29, 2014 | Bosch TASSIMO Coffee Makers & Espresso...
I have had this coffeemaker for about two months and use it daily. Yesterday the machine refused to make coffee, it would perk and perk but very little water came through into the coffee pot. The self...
We had the same problem and it seemed to be caused by the little charcoal filter. We took it out and the machine worked fine. replacements are available, but expensive. (2 for $9.95)
Dec 03, 2010 | Cuisinart DCC-1200 Coffee Maker
I have a mr. coffee maker mrctb and it will not dispense water . why Thanks Jim
try running straight vinegar thru it . Sounds as if the water feed tube is clogged, with scale from unfilted water, try that and see if the vinegar comes thru. If the vinegar flows thru it the water will too
Jul 11, 2009 | Kitchen Appliances - Others
My stainless steel Mr. Coffee maker just quit perking coffee and the water does not run totally through. It has been perking slower and less quantity but today I cleaned it by running vinegar through it...
this is set up on a conventional mr coffee; if the hot plate is not as hot, it will not work, on the newer ones, a small chip could be getting hot, and like a car, it will either shut down or work part time. send it back to mr coffee, and they'll repair it, but it might be cheaper to replace it.
Jul 02, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Commercial bunn coffee maker that the water only dribbles out
In addition to running vinegar thru your coffee maker, remove the sprayer at the point where the fresh coffee comes out to enter the carafe. It is a disk about the size of a half dollar with several small holes in it. Use a small piece of wire to clean out each of the holes and you should have the speed back. good luck.
Jan 27, 2009 | Bunn Counter Top Coffee Brewer Commercial
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Cuisinart coffee maker... How do I clean the inside metal craft?
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused 2-3 cups only produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
don't forget to rate
Aug 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
How do i clean the cuisinart coffee maker? also, where i get the filters for the machine? thanks, JPG
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused only little produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
Hope this may help;
Regards,
VOTIT
don't forget to rate;
Black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Sep 20, 2007 | Wega Mininova EPU Espresso Machine
Black & Decker Spacemaker  10-Cup Coffee Maker Logo
180 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
