Question about Electronics - Others
Please me asap
My digital mp3 player is battery less you have to charge it up by computer. do you no were i can find a online manual if not can you help me with my problem. i think it has sleep mood if it do how long does it take
    Scholar:
  • 191 Answers
You will find online manual regarding your product in the manufacturer's website. So go through it you will find online manual support...
Posted on Sep 28, 2008
How to operate a eclipse mp3 player
Hi cindy22258...
Go to the following webpage and download your FREE eclipse CLD2 user manual
It will tell you the complete operation of your MP3 player.
Please take time to rate me thumbs up
http://static.highspeedbackbone.net/pdf/Eclipse_CLD2-manual.pdf
Sep 26, 2011 | Eclipse CLD2 MP3 Player
I have an iq sound 4700 that i bought two days ago but it seems that its taking longer to charge.whenever i take the plug out, i cant switch it on. need help ASAP?
dear, you do not mentioned that how long stand by your battery gives you after charging.
and if your mp3 every showed battery full after charging.
well since your mp3 player is new, it must not have any problem in battery, i think your charges has some fault. Go to the shop where you purchased your mobile.
they may make it for free.
well,
if your battery shows charged full, and gives a long stand by, then your battery is 100%good.
you need to change your charges, or an integrated circuit which help to keep charging you mp3 player., this circuit defines how long it have to take to charge you mp3 player.
best of luck!
regards!
Jul 22, 2011 | Bell Technology IQ Sound SC-2528 MP3...
Sony bean mp3 problem reply ASAP
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Mar 27, 2010 | Sony Walkman Bean NW-E307 MP3 Player
Walkman won't charge ,plugged into computer for 1 hour, but comes up low battery and switches off
I pressed a pin into the" reset " on the bottom of walkman this seems to have done the trick
Jul 17, 2009 | Sony Network Walkman NW-A3000 MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Short Battery Life on insignia 4gb player
sounds like the rechargeable battery has gone bad.  Replace the battery and don't let the player cook in the wall socket next time.
Mar 24, 2009 | Insignia Pilot MP3 Player
Charging my 2gb sansa clip
You can charge it by leaving it plugged into the computer for 3-4 hours (usually less).
Nov 12, 2008 | SanDisk Sansa Clip MP3 Player
Dell dj mp3 player won't charge
You need to install the Playforsure firmware update. That will solve the problems.
Nov 07, 2007 | Dell DJ MP3 Player
Wont charge!
go to the insignia website and under retail you can order a battery
Oct 23, 2007 | Insignia NS-DV2G MP3 Player
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
