Question about Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
Hi, How can I get my label maker to change from horizontal to vertical for printing?
Press the Style button (just under the screen) and select the sideways symbol.
Jo
Posted on Oct 17, 2008
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
Changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Apr 06, 2009 | Dymo LetraTAG Thermal Label Printer
Dymo Letra Tag
Hi - You can download the manual by clicking the link underlined in blue below:
letra tag QX50
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 17, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
I have to assume you are pressing the print button. That being the case, either your batteries are weak or the tape is empty or jammed.
Aug 28, 2008 | Dymo LetraTAG Thermal Label Printer
Letra Tag XR
hi
on this site on the top left you can download the user manual form there Dymo LetraTag XR
hope this helps
riz.
Feb 21, 2008 | Dymo LetraTAG Thermal Label Printer
RE: Dymo Letra Tag
If you use the "dynmo letratag 2000", just press the shift button (the green arrow button) and then the letter "N" (above that letter you should see the text "2=").
That will add a carriage return on your current position and the following text will appear on the second line when printed.
Nov 14, 2007 | Dymo LetraTAG Thermal Label Printer
Dymo letra lable maker,
there is no ink in the letratag. just replace the tape and/or the batteries.
Oct 04, 2007 | Dymo LetraTAG Thermal Label Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
420 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
