Question about RCA L46WD250 46 in. LCD HDTV
Unusable signal did you get the unusable signal fixed. I need to kniow how to fix it It is a new RCA 46 in LCD
If you are handy and can sold, order the fuse from digikey. They have it for like 3 bucks but it is tiny. Hook up a dvd player first to the hdmi plugs to verify it isn't an actual signal problem. The fuse blown will give you a picture but no sound.
Posted on Oct 02, 2012
It was a fuse in the digital board i took it to an rca repair shop and had it fixed has been working great since
Posted on Sep 28, 2008
Rca entertainment series unusable signal
i think your rca cord is not functional. replace it with another one or fix the connections of your cord.
Jan 04, 2014 | Televison & Video
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
Sharp Aquos LC46lE700UN How do I adjust the audio. Manual says that the Output Select to Fixed, but it still does not allow me to adjust the audio
If the RCA audio out put is set to 'FIXED' it means the signal at the RCA jacks will not be controlled by the Volume control of the TV, but the TV speakers will still be controlled by the TV volume control, if you want to make the RCA AUDIO out to be adjustable by the TV volume control, you will have to set it to 'VARIABLE'.
Nov 03, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
Rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Jan 03, 2009 | RCA L37WD12 37 in. LCD HDTV
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
RCA L37WD22 not receiving analog
The problem is on the signal board. Same problem and fix for L42wd22, and L46wd22 models.
I can fix this board for a FRACTION of what a repair tech will charge you. Email me at aplusrepairs@triad.rr.com
May 11, 2008 | RCA L37WD12 37 in. LCD HDTV
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
RCA L46WD250 46 in. LCD HDTV Logo
705 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
