Question about Kenmore 43142 Front Load Washer
F03 error on 2 way tumble action washer
My clothes will not rinse and spin out
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
When the clothes are wet at the end of a cycle, check these:
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Sep 28, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
vickygomar
  • 460 Answers
SOURCE: he2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
Posted on May 12, 2009
  • 212 Answers
SOURCE: Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Posted on Jun 24, 2009
  • 50 Answers
SOURCE: front load frigidaire washer w/ error code
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Posted on Jan 06, 2010
Tumble action washer will not spin to remove water from cloths, however it does tumble the cloths during wash cycle, just does not have the high spinning required to remove excess water
This could be a simple fix or the expensive one. Let's try the simple fix first. All dryers have a safety feature for when the washer spins ( mostly for kids to not stick hand in or open lid up when washer is spinning at high speed, to prevent injury) On the lid it self (underneath) has a peg or button that when closes goes into a slot or hole on top of the washer, otherwise known as a switch. Sometimes that switch goes out which has to work for the washer to spin, or has to be bypassed. If you don't know much about bypassing or wiring I would buy a new washer lid switch. There probably under 20 bucks, and easy to replace. Now the expens
May 07, 2011 | Kenmore Washing Machines
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
The drum is not spinning and the machine stops and has LE on display
Sorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
Error code LE
In new installations, this error can sometimes present because of a mis communication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
3 Thumbs - Helpful
3 Thumbs - Helpful
Dec 27, 2010 | LG WM1814CW Front Load Washer
Whirlpool dryer error code
Your TECH SHEETS mention "Sud" If too much detergent was used. Why? You get that computer thinking suds is in there and the machine is gonna go into a tailspin. Because of the low amount of water
used in HE machines, it is important
to use an HE detergent (low sudsing)
which is specially formulated to work
best under these conditions. The two
most important considerations of a front loading washer are sudscontrol and soil concentration.
First, the tumbling action in an HE machine generates
more suds than a top loader. Tumbling the clothes in and out of the water breaks the water surface
causing air to be trapped in the solution,
creating suds or foam. Multiple problems
can occur from oversudsing, such as
flooding from suds overflowing out of
the machine, formation of a suds cushion
during the tumbling action which reduces
mechanical energy,and “suds lock” which prevents
the machine from effectively spinning out the
water. In the situation of suds lock, the
machine tys to FIX the foaming poroblema by
stopping the cycle momentarily to allow
the suds to dissipate and then adding cold
water. This routine the machine goes
through to correct for over-sudsing results
in loss of energy and water savings and
can significantly lengthen the cycle time
(sometimes by as much as 2x). HE detergents
prevent over-sudsing and allow for better rinsing of suds. HE detergent matters in soil management also. Though HE washersuse about 1/3 of the water of a
top loader, the concentration of soil in the
load is much higher due to the larger
loads. To handle the higher amount of
soil, many HE detergents are specially
formulated with soil suspending ingredients
to prevent soil from re-depositing
onto clothes. Only use detergent with HE marked on it. Use the correct amount.
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
4. Check/clean drain pump filter of foreign objects.ec9f016.jpg
5. Plug in washer or reconnect power.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle. Your tech sheet will be behind the bottom panel and will resemble THIS Suds is on page 6
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Tumble Action washer won't complete the final spin. leaves clothes soaking wet.
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ AppliancePartsPros.com .
Dec 08, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Frigidaire Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Automati Washer Spin Cycle
never heard the vinegar in the rince water thing but who knows! do you know if the washer drum is working in the wash cycle? as you know it should tumble in both directions. if you ca check that it would be a big help to know if the motor is working. it could be something as simple as the belt broke. so get back to me with the answer and we can go from there. thanks
Aug 04, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Kenmore 43142 Front Load Washer Logo
43 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
