Question about Frigidaire FMV145K Microwave Oven
Hello there is F3 that reads in the small monitor I cannot find my manual can you help and tell me what that it means As of now or microwave is not working Bien
  • bien bien Sep 25, 2008
    thanks for the immediate response yes my model numebr is FMV145 . I tried unplugging and plugging it back but it seems some of the keypad is not working when i pressed it initial i able to put the clock and microwave works for a few minute then it will start some kind of sounds and F3 returns back
    Bienbien
  • William Miller
    William Miller May 11, 2010
    Is your model number FMV145?
    If not, what is your model number?
    Are you in the US?
    Is F3 the only code that you see on the display?
    If you unplug the oven, wait about 2 minutes, then plug it back in and set the clock, does the F3 code come back on automatically? How soon?
    Does this code only come on when you press a certain pad? Which pad?
  • Frigidaire Master
  • 9,098 Answers
I would think you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 26, 2008
I have Amana microwave hdc182 displaying f3 code what dose this mean?
According to the tech info manual, when you get a code F3 you need to replace the HV/LV board. Here is a link to the manual for your reference.
Jul 02, 2015 | Amana Microwave Ovens
HOTPOINT COUNTERSAVER PLUS RVM 1435 DISPLAY READS F3
"F3" on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On RVM1435-series microwaves, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (RVM1435XX###) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 23, 2011 | Hotpoint RVM1435 Microwave Oven
HELLO. I HAVE A GE MICROWAVE MOD JE1860WB. THE MONITOR READ "F3" CODE. WHAT IS THAT?
The F3 code means that the Key panel also called touch pad is shorted. This code usually comes up when when the Microwave detects the shorted panel continuously for over 60seconds.
To correct this error, you have to Replace the key panel also called the touch pad.
Thanks.
Sep 14, 2011 | GE JE1860 Microwave Oven
We are getting an F3 message on GE JVM1750DM microwave. After turning off power and then back on. It works for a few minutes, but then the F3 message come back ?
Hi
F3 error in your GE microwave means that the keypad/touchpad is bad and should be replaced. However, before replacing it you can follow these step by step instructions to clean the touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover moisture
8) After this put the keypad back if its not solved then replace it.
Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | GE Microwave Ovens
My ge microwave is showing a code of F3. model JES1034 what does this mean?
hello there
Tthe f3 code is referring to a faulty touch pad which may need to be replaced i would contact the manufacture of this microwave for a parts replacement
Jul 29, 2009 | GE Microwave Ovens
Ge microwave
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a microwave Model#JES1036WF Serial # SD901831S. It comes up with a F3 on the keypad & goes off on its own - just starts by itself. I dont have a manual for it so dont know what the F3 means or...
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
May 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
MY MICROWAVE READS F-3 AND IT PEEPS AND WON'T SHUT OFF. THE FAN KEEPS RUNING AND I CAN'T SHUT THE MICROWAVE OFF AND IT KEES BEEPING. CAN YOU HELP ME
F3 error means that the oven tempeture sensor is open circuit. You will need to replace it.
I have already forewarned you about the voltages inside microwaves. BE SURE TO DISCONNECT THE POWER!!
Hoping you could give me a FixYa for that one :)
regards
robotek
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave f3 problem
WHAT DO YOU MEAN BY (F3 PROBLEM)? MORE INFO PLEASE.
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave malfunction
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
93 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
