Question about Panasonic DMR-EH65 DVD Recorder/HDD Recorder
Panasonic DVD recorder does not read Disks
My Panasonic DVD recorder DMR-EH65 stopped in the middle of a high speed copy to DVD and now does not read any disks. It shows a "NoREAD" in the display whenever the tray is closed with or without a disk in the tray.
  • 3 more comments
  • itegis Dec 24, 2008
    My Panasonic DVD recorder stopped when trying to start to copy to DVD and now does not read any disks. It shows a "NoREAD" in the display whenever the tray is closed with a disk in the tray.My Panasonic DVD recorder DMR-EH65 stopped in the middle of a high speed copy to DVD and now does not read any disks. It shows a "NoREAD" in the display whenever the tray is closed with or without a disk in the tray.
  • technophile Jan 12, 2009
    My DMR-EH65 stopped with error message U88 during high speed copy to DVD. It then performed the recovery process. Since then it cannot read / recognize any DVDs. It appears to attempt to read a disk whether one is in the drive tray or not.
  • Anonymous Jan 26, 2009
    Same here. While burning a dvd, the machine stopped. U88, problem with disc, and since then it doesn't read any disc at all. No movies, no DVD-R, blank or written, nothing....It also makes a sound like it's trying to scan the disk, it tries six times and then stops...
  • oceanic_srn Feb 05, 2009
    My DVD recorder was formatting a blank DVD/disc, then stopped and said there wasn't a disc inserted. Any form of DVD or CD we insert will not be picked up by the player. I'm guessing it'll need to be serviced, but I'd like to know if I can fix it myself.
  • fseven Feb 28, 2009
    same Player and same scenario, was copieing fr HDD to DVD and the player stoped mid burn, now wont play anything in disc format. Hdd still goes, get NO READ on screen and DV on player
  • 11 Answers
SOURCE: dvd noread
If you put a disk in and it just clicks several times, it's more than likely the spindle motor. It's best just to replace the DVD drive. My own theory is that when you record in the high speed mode, it is just too much for the spindle motor to handle over time. I keep my record speed in the standard mode to play it safe.
Posted on Apr 09, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
pogiboi
  • 85 Answers
SOURCE: replacing the HDD
hellow
before you replace your hdd ,,
step1. format the new hdd on the pc FAT system
step 2 . set the player 2 default set then replace the hdd..
reply this post when not work
SOURCE: panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Posted on Feb 10, 2009
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Posted on Jul 25, 2009
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
No read,It will not read any dvds? seams as if its not spinning the discs
No i did not get it fixed as all you people are doing is keep sending me email to join your site. not one replie to my problem thanks for nothing
Dec 07, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Hello, I have a Panasonic DMR-EH65 DVD with HDD, when pressing any button on the remote control the display says DVD3, machine will not operate, took it apart to check for any bad connections, reassembled...
You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Mar 15, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
I want to transfer all files on DVD recorder to PC
There is no function on the EH65 to back up your files to your computer or an external drive.
The only thing you can do is transfer your cherished files to DVD-R then put them on your computer. Any other way, like playing the file and re-recording on your computer will result in poor reproduction.
Dec 17, 2008 | Panasonic DMR-E55 DVD Recorder
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
DMR-EH65 DVD
just bring it to service man near you coz that is IC problem
Apr 23, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Replacing the HDD
hellow
Apr 20, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Panasonic EH65 HDD/DVD
Dis connect from the mains- wait a while then re connect what happens?
Jul 12, 2007 | Panasonic DMR-EH65 DVD Recorder/HDD...
Panasonic DMR-EH65 DVD Recorder/HDD Recorder Logo
585 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
