Question about Whirlpool Duet GHW9150P Front Load Washer
F25 error code
I started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
  • 1 more comment
  • twelsh2 Oct 13, 2008
    Since I posted my problem over two weeks ago, waiting this long for a response was not feasible -- I do have laundry to do! I ended up calling the repair service through Lowe's (which is where we purchased the washer). That guy said the motor was locked up and he had never seen that before on a washer -- especially since it's just one year old. We bought the washer on 9/3/07 and it broke on 9/23/08 -- and Lowe's was not willing to help in any way -- the lady said we should have purchased the extended warranty!! I ended up having a friend of ours who owns an appliance repair service fix the washer for us at a savings of about $75 from the Lowe's service company (I still ended up paying a total of $325 on a washer I purchased a year ago for $800 -- great investment!!)
    I would not recommend this washer as I also have the 'smelly' laundry that many have posted about. I have learned to keep the washer door and the soap dispenser open to let them dry out between washings. I also don't like having to untangle a load of jeans when I put them in the dryer -- the legs get all entwined with each other in the wash cycle.
  • Anonymous Oct 29, 2008
    What did your friend fo to fix it? We get the F25 error when we try to wash clothes, but the delicate cycle does work. It is like the aggitator doesn't work.
  • Anonymous Mar 31, 2014
    code f25 shuts down washer
Huuum has it right on the meaning of the code. If you take off the lower cover with three screws, you will find a tech sheet which lists the code. I checked the wire harness connections, and sure enough, at the side of the motor, they were loose. Had probably never been fully connected. I snpeed them together and problem solved. I was really pleased because the washer was only 8 days out of warranty!!
Posted on Nov 25, 2008
  • 750 Answers
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Posted on Oct 13, 2008
  • Neil Golan
    Neil Golan Oct 13, 2008
    For the smell I tell my customers to wash their whites in hot water with bleach once a week.
    This gets rid of the smell usually.
Code F25 on my whirlpool washer
F25 is a MOTOR CONTROL error . check for past posts in Search as there were some in 2007 shown on Fixya . or check throgh Google / Internet explorer by stating F25 Washing Machine error
Jan 09, 2018 | Whirlpool Washing Machines
My whirlpool front load washer will not spin out. its showinf error code F25
According to the tech sheet, F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch. Since there a various reasons for your problem, I just can suggest starting point since there is a code displayed.
Dec 23, 2016 | Whirlpool Washing Machines
F25 code on 3000 series maytag washer
Google search brought up:-
F25
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
A serious and difficult fault to repair. Call a technician.
Nov 13, 2016 | Maytag Washing Machines
SAMSUNG J1253 ERROR CODE 4E
Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
May 03, 2017 | Samsung Washing Machines
Push start and machine wont fill and draining/unlocking light sarts blinking about 2 seconds later
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
Jan 24, 2011 | Whirlpool WFC7500VW Washer
My he5t is giving me f25 code. i have pressed stop and tried to drain but i get f25 again. do i need a new belt?
Here is the info on "F25":
f25_code.jpg?t=1177554999
When you open the top of the washer, look at the black rubber hose leading up to the pressure switch. If the hose is kinked, it will fool the pressure switch into thinking the washer is either full of water or it did not see a water level change after the water valves have been on for a period of time. These failures generate the F20 / F25 codes.
To Clear the F25 Fault. Disconnect & Connect the "Water Level Presure" switch plug, a couple of times, Give it a couple of light "Taps" Reconnect again, and see if that works, it should.
Feb 16, 2010 | Kenmore Elite HE5t Washer
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
F25 code for brand new washer
F25 is a keys stuck error code which must be covered under warranty..The only option is to replace the keypad..I suggest that you pester those customer support fellows so that you can get it fixed as it is a pretty complicated process to do it yourself..
Oct 23, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,009 people viewed this question
Dan Webster
Dan Webster
Sal De
