Question about ViewSonic VA702b 17" LCD Monitor
ViewSonic 17" I tried 3 different monitors attached to an Acer 5200 and all three are telling me there is no signal. I've exchanged at least 10 of these monitors out throughout my school district and never had this problem before. These were brand new monitors straight out of the box.
  • 64 Answers
I would check to make sure you have the proper input settings selected and also make sure that the resolution is set properly. If those are good then I think you should try hooking up a different monitor to your laptop and see if that works; if another monitor doesn't work then there's a pretty good chance your VGA output it probably bad.
Posted on Jul 16, 2009
New Viewsonic LED monitor displays No Signal on two refurbished Dell 2950 servers (both front and back VGA adapters embedded on motherboards) but monitor works plug & play on three different laptops....
Well you ruled out the monitor
Most server have a detail error report system in most cases shows combo of led lights that tells you what its doing and where it is hanging
I sugest to find a manual on it and see if it goes to the post without a hitch
Mar 13, 2015 | Dell Computers & Internet
LCD monitor (viewsonic va720) "No signal"
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 05, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
My omnitech monitor is turning red when it wants to. no certain program just whenever
Colours on the screen are generated by "mixing" the 3 primary colours.
Of the primary colours is RED.
So, your LCD monitor is not receiving signals from your computer,
specifying the other two primary colours.
Check the data-cable between your computer and your monitor,
to ensure that the connections are tight at both ends.
Try a different data-cable.
Try your monitor on a different computer, with two different data-cables.
Try a different monitor on your computer.
It could be the video-card inside your computer is failing to "send" one or two of the primary colours.
Dec 31, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Osdlock on my computer desktop for 17'' monitor
You are having a problem with the OSD lock on your ViewSonic E70f Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
Viewsonic E72f+ OSD Locked
press and hold the 2 button... the button which has named 2 on it... for some seconds... maybe 10...
Jan 03, 2009 | ViewSonic E70f 17" CRT Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
ViewSonic VA702b 17" LCD Monitor Logo
78 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
