Question about Onkyo TX-DS696 Receiver
No Output (Where is the protection circuits?) i.e. speaker fuses or breakers.
Short of buying a $15.00 service maunual where do I locate the protection circuit and is it fused or breakers.
Where and how available are the output trannies for this model?
Thank You,
  • 4,234 Answers
The output transistors should be mounted to the heatsink in the rear. These should be changed as complimentary pairs. If you have a diode checker or an ohm meter, check these transistors for a shorted condition. Depending upon why the protection circuit is kicking in, you may need to change some components in the driver circuit too. The transistors used here should be readily available. I don't have the service manual with me at the moment, so I can't give you the exact part numbers.
Let me know if you need more info.
Posted on Sep 25, 2008
Outlets not working all fuses are good
The following electrical components (if so equipped) will only operate when your
RV is connected to shore power: 120 to
12-volt power converter, air conditioner,
120-volt refrigerator, microwave oven, television(s), fireplace and appliances
plugged into convenience receptacles.
The 120-volt AC circuit breakers located in
side the main load center protect all
120-volt wiring and components in the RV fr
om circuit overloads and short circuits.
Should a circuit overload or short circui
t occur the circuit breaker protecting the
affected circuit will "trip" preventing the flow of electricity through that circuit.
If a circuit breaker trips, shut "off"
the appliance on that circuit (i.e., power
converter etc.) and allow the circuit breaker to cool down for a brief period of time.
After the cooling down period, reset the circuit breaker by moving its lever "off" and
then back to the "on" position. If the circuit breaker re-trips or frequently trips,
contact your dealer to have the electrical problem diagnosed and repaired.
A circuit breaker identification label is permanently attached to the inside surface
of the 120-volt load center.
Maintenance and Replacement
At the beginning of camping season, inspect the circuit breakers and replace as
needed. Test by turning each circuit breaker "off" and back "on". Circuit breakers
are wearable parts and must be replaced
as needed, as part of your RV
maintenance. If you have any questions, consult your dealer.
Please contact your dealer for repair assistance when replacing circuit breakers.
The power converter converts 120-volt AC power to useable 12-volt DC power
when the shore power cord is connected to an external power source.
The converter has a built-in protective thermal breaker that will shut it down should
overheating occur. Overheating can be
caused by operating the converter above
its maximum power output for an extended period of time, or by an obstruction to
its ventilation air flow. To reduce converter heat build keep unnecessary 12-volt
lights and motors turned "off"
Keep the converter cooling fins and fan clear of
Inspection and maintenance
If the 12-volt power converter is not working (auxiliary battery not being charged)
check the reverse polarity fuse(s) in the converter fuse panel.
There are no
customer serviceable parts inside the converter case and the
manufacturer's warranty will be void if
the case has been removed
. If you
have further concerns contact your dealer.
Nov 16, 2014 | Jayco 2013 Jay Flight Swift 264BH
My amp has a protection light on need to know how to fix. When I pull the fuses out the power comes in but when I put the fuse back in the protection light comes back on
From the description your audio output transistors or ic's have a short causing a load problem activating the protection circuit. Turn volume right down, power off, remove speaker wires from the back, power on! if protection kicks on it is the audio outputs in the receiver, if not! check speaker wires for shorts, hook back one at a time until defective wire or speaker is located. The audio outputs will need to be addressed by a technician since there is complexity involved.
Mar 03, 2012 | Legacy Car Audio & Video
My protection light is on and the amp goes in and out. how can i fix this problem?
Either there is a malfunction on the amplifier , or more likely there is a short on the speakers cabling. If the cables are shorted, or broken, not allowing a sufficient load, the amplifier will protect itself by tripping a fuse. After a while, or on restart, the fuse will rearm itself, only to be tripped again by the malfunction.
Jul 28, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Is my circuit breaker box the same as a fuse box? My dryer isn't working.
Yes,but no one should have a fuse box in
their home, for the last 40 years.
Not Code to have one
Feb 16, 2011 | Dryers
(I think) our bass player plugged from the output on a powered desk in to the input of our JBL MPro 18" sub (MP418SP) powered by crown Amplifiers. Now the fault light is constantly flashing and...
I'm assuming you mean he plugged an amp output (meant for a speaker) into the input of one of the Crown amps powering the sub-woofer. Right? Crown amps have good protection circuits and are high quality units. Some models have internal fuses but you didn't list a model here. If they are fused (or some kind of breaker) you should be able to see those by opening the top cover (amp off and unplugged). It is unclear if you tried to use the amp again after this incident.
Some Crown amps have protection circuits that will reset themselves after the fault is removed. In this case, you should remove both inputs and output (speaker) and power it up. If the amp doesn't light any protection lights or indicators, then turn it off and connect a known good speaker (not the subwoofer) and a source you can control. Set a low volume and see how it goes. You can really try either approach first depending on what's easier.
Jan 28, 2011 | Audio Players & Recorders
Short circuited rear left speaker cable which seems to have killed that output. Don't they have short circuit protection on MOSFET amps?
Even with the protection the outputs will blow if the "short" was not complete.
The heat will build up and waste the driver. Almost shorted will do this almost always.
There may be an internal fuse that blew. Ask a shop if that model is fuse protected.
Jan 23, 2011 | Pioneer Car Audio & Video
Pioneer 12v car amp rated at 1200 watts max requires ? amp fuse
Hi I would suggest 40A (i know guys will disagree) but you shouldnt be running at full 50A. Fuse are often rate at 50% - 75% of the actual consumption. By the way, 8 guage @40A will give you about a 2% drop at 5 feet. Maybe consider heavier for 40A?? Just a suggestion
Jul 24, 2009 | Audio Players & Recorders
Where are the fuse boxes for a 1987 cadillac de ville
prev.gif next.gif Circuit Breakers A circuit breaker in the light switch protects the headlight circuit. A separate 30 amp breaker mounted on the firewall protects the power window, seat, and power top circuits. Circuit breakers open and close rapidly to protect the circuit if current is excessive. Buzzers, Relays, and Flashers The electrical protection devices are located in the convenience center, which is a swing down unit located under the instrument panel. All units are serviced by plug-in replacements.
Jul 13, 2009 | 1987 Cadillac DeVille
Marathon 2000 amp... PROT light
Ok this means the AMP is in protection mode!..most likely the cause is a short in your wireing from the speaker wires! check all wires going in and out of amp! Look for stray wires touching metal or other contacts! (If this does not fix it the short may be inside of amp!
(This has nothing to do with a fuse!)
Please rate this FREE response!
Jan 19, 2009 | Marathon DJ-2000 Amplifier
I have a fosgate 301x with power to the amp but none coming out
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure.
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Onkyo TX-DS696 Receiver Logo
154 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
