Polaroid Freescape 4360 PMP...database problems?!
Hi
i have a polaroid pmp, for my sins...
i was deleting all my files from it but seem to have deleted some crucial files belonging to it too...
i put new files on it, mp3 and pictures...and i can access them when i hook the player up to a pc...as in, i can access them on the computer, but then when i disconnect from the computer there's nothing.
it simply states "database error: unable to create database due to insufficient disk space"
what have i done wrong and how can i put it right?! much appreciated
brian in ireland
  • Anonymous Dec 30, 2008
    I have Polaroid Freescape 4360 pmp and i have the same problem about database ( system error Unable to create Database ). I dont install the firmware because the media player option is not avaible! File system is FAT32.
  • 3 Answers
Doesnt use CE. Power up and hold the middle touch button. Select option to rebuild the database.
Posted on Aug 16, 2009
Not really a solution, but this item uses win ce 5.0 as it's operating system.
you may need to reinstall this somehow. not sure how though.
i would have thought the os would be stored on a seperate partition so that you could do this, but not found any so far.
Posted on Jul 19, 2009
Polaroid mp4 pmp 120-4
are you plugging it in to your computer or a usb hub? if one of those is what you are using and it doesn't work, then try the other. if neither of those work, I would suggest using the Polaroid support line: 1-877-768-8483. Mon-Thurs 9AM-5PM and Fri 9AM-3PM. (Eastern Standard Time)
There is also an email:
polaroidsupport@southerntelecom.com
I hope you find a solution
Jun 30, 2013 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
Polaroid pmp 105-2 is missing installation software.
It's supposed to have software? I went to Polaroid's website & it doesn't list any MP3 players, so I couldn't find a place to download drivers
Aug 22, 2011 | Audio Players & Recorders
I have a polaroid 4 gb mp3 music player PMP-100-4 And I can't figure out how to erase songs already on player. I get to "delete all" but don't know what button/s to...
Hi ettaesque...
Remove the songs the easy way...follow the instruction below:
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
This is a FREE answer, Please take time to rate me
Jun 25, 2011 | Polaroid Audio Players & Recorders
I bought the polaroid 4GB touch pmp 280-4 for my daughter and it worked for the first week after she got it. Now it wont turn on. can someone tell me how to address this issue? thanks, Shannon
tengo un polaroid de 4GB pmp 280-4 el problema es que e vajado videos pero cuando lo quiero ver no puedo por que dice que no es el formato este es el problema que tengo con eso si puedo vajar musica y escucharlo pero no puedo ver los videos que bajo por que dice q no es el formato ps
Feb 03, 2011 | Polaroid Audio Players & Recorders
What video format is used for polaroid pmp 180 ?
The converter on the player recodes to a .avi file. it will REcode regular .avi files to a smaller screen size.
Dec 26, 2010 | Audio Players & Recorders
Need to disassemble Polaroid Freescape MPU 043315B
Hi Integral17,
It sounds like your database is corrupt. Here's something to try. While the device is booting, press the pause/play button several times (about once per second). If you hit the pause/play at the right time during the boot process, it will invoke a debug menu that will allow you to format the disk. Format the disk and see if that resolves the problem.
Let me know if this does not work.
boozinitup@yahoo.com
Sep 24, 2009 | Audio Players & Recorders
My Polaroid Freescape 60GB MPU-43315BMedia Player has crashed and
Power up, hold the middle touch button. Select rebuild the database.
Apr 15, 2009 | Polaroid MPA-20011S Digital Media Player
Boot failure
1st go to Ihttp://www.shamrockman.net/ and dload the version you want to run. My PMP shows 1.23 but I couldn't find that version so I now run 1.24.. Save the dloads in a new folder on your computer.. There should be (7) items that dload to your computer.
*** I have found that just copying the files to your PMP Player will NOT work.***
I had to delete ALL (7) of the system files and folders.
1.) BMP folder
2.) etc folder
3.) system file
4.) (4) "Version-[0x..... " files..
So there were (7) items I had to delete. Once deleted go to the folder you saved the dloads to. I had to click and drag each item to the drive your PMP player is connected to. Once all (7) items have been placed on your PMP player disconnect it, turn off the power, wait a minute and turn it back on. These steps worked PERFECTLY for me. Please let me know in this forum if this helps..
Thanks..
Jan 02, 2008 | iRiver PMP-120 Digital Media Player
596 people viewed this question
 Grubhead
Grubhead
