Question about Panasonic Proline AG-DV2500
Small tape won't load - large tape will
Large DVCAM tape will load. Small miniDV tape will go all the way in, but then a loud continuous clicking noise happens, the tape doesn't get seated fully, then it ejects.
    Champion:
  • 221 Answers
Defective cassette housing
Posted on Dec 04, 2008
DSR-1800A DVcam TAPE EJECT ERROR 21
This error means the reel position motor is not moving the reels either together for mini DV or appart for large tapes. Usually because the sliders or gears have run out of lubrication and have seized due to not being serviced periodically. Otherwise there may be a foreign object stuck in there like a torn label etc.
Try a different size cassette tape, it may be ok on large if you are trying small or vice-versa, because it is already in that position.
Jul 12, 2012 | Sony DSR-1800 DV/Mini DV VCR
The large black ink tank is empty but the small black ink tank is full, why won't the printer print from the small ink tank?
The small black ink is only used for printing photos and must be used in addition to the large one. If the large one is empty, it will not work.
Jun 28, 2011 | Canon PIXMA MP600 all-In-One InkJet...
The belt on my Kenmore washer model no. 110.45091401 is shredded. How do I replace it?
REMOVE BACK PANEL ON FRONT LOAD WASHER PUT BELT ON LARGE PULLEY AND TAPE BELT TO LARGE PULLEY TAKE OTHER SIDE OF BELT AND STRETCH TO MOTOR PULLEY WHILE ROATING LARGE PULLEY WALKING BELT ONTO SMALL PULLEY OR LOSEN MOTOR BRACKET PAY ATTENTION TO LOCATION OF MOTOR BRACKET ALIGNMENT PUT BELT ON BOTH PULLEYS PUSH MOTOR TILL BELT IS TIGHT AND RETIGHTEN BELT
Jan 26, 2011 | Kenmore Washing Machines
The deck will accept a large tape but not a small one. I do not get an error code the small format just won't seat.
Most likely problem is the flat cable in the cassette housing. This cable breaks, and the sensors for large/small tapes can't tell the deck to move the reel tables to accommodate the tape.
Feb 17, 2010 | Sony PVW-2800 VCR
Sony 570 dvcam error message 91-143 can you help
Microcomputer and its periphery device error
1: CASSETTE IN
4: Capstan motor/capstan FG
2: Detected speed error
It looks like a bad capstan motor.
Dec 15, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Tape deck no longer plays large DVCpro tapes
the tape compartment elevator has switch senors that tell the machine what size tape is in..
does the tape load all the way.. you need to tell us
is there an error code ?
either the sensor or the reel motors the feed and uptake the tape,,
they ride on rails and slide into position to accomodate the tape side they could be having trouble moving, dirty, broken actuator
Apr 07, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
With MiniDV tapes, the DVCam indicator ignites and the reading becomes jerked.
It could be several things causing your problem. The video head may be worn, the tape guides may be out of alignment or you may have a mechanism problem keeping the tape from wrapping securely around the rotating drum. If you can use an oscilloscope, you should check the RF signal coming off the drum test point to see if it is clean, or if half the signal is missing (bad drum or video head) or not smooth (guides out of adjustment).
Nov 08, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Tape stuck inside
there is screws on the unit when the unit goes into rewind mode disconnect from mains and unscrew unit first check to see if the screws are scurity type haveng a hex or star shape on them if either then take to video and tv repair shop and explain that you need to remove a tape from unit you may have to pay for a small fee for it to be removed this part is all i can give but if you can remove screws yourself then locate the motor for tape ejet and load and manualy wind till tape is removed good luck
Aug 06, 2007 | Sony DSR-11 DV / Mini DV VCR
Won't record on Large tape
check the cassette housing - the flexible cable in the housing may break, resulting in problems with large tapes.
Jun 05, 2007 | Sony PVW-2800 VCR
Panasonic Proline AG-DV2500 Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
