Question about GE WCVH6260F Front Load Washer
How to secure front loading drum for moving????
I need to move a GE WSSH300-GOWW up a flight of stairs, 40 miles down the interstate, and then down a flight of stairs. What do I need to do to secure the drum. The manual says to use the shipping hardware, but the owner did not save it. Are these standard bolts?
  • Chris72IL Sep 25, 2008
    Thank you very much. Should I transport the unit on its back, or in the upright position?
    President:
  • 1,462 Answers
Transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Posted on Sep 25, 2008
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Sep 02, 2014 | Mitsubishi WD Televison & Video
I have a LG WM0532HW. What are the drum bolt sizes thr.& length
Hello Jeff,
Unfortunately, these are specially made bolts that have threads only on the first section of the bolt, so they can secure the wash drum and not interfere with anything else. You also need the special sleeves for the bolts. I would not try to use standard bolts from a hardware store, as they could damage the wash drum if you overtightened them or they were too long. LG, and most washer manufacturers, don't publish the size, thread count and length of their transport (shipping) bolts, hence the reason they advise to keep them for future use.
So if you're only moving the washer down a set of stairs, you should be fine if you take it easy and either hand carry it with two (2) people, or use an appliance truck to move it down the stairs.
If, however, you're looking to move the washer any distance via truck, etc., you'll want the shipping transport bolts and sleeves to keep the drum and suspension system from getting damaged.
You're best bet is to get in touch with LG customer support and obtain a set of the transport bolts. You can reach them by callling them from 8AM to 8 PM toll free at 1-877 714-7486 and follow the prompts to reach customer support.
Here's a link to the owner's manual for your washer, just in case you've misplaced yours.
http://aic.lgservice.com/gcsc/dwn/main
Hope you find this Very Helpful and best regards!
Dec 13, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lost or not retained shipping bolts
Just looked at mine (we had to order them before the military would move ours). They are two different sizes, have a long plastic washer (lengthwise), and are - believe it or not - like a lag bolt on the end! A hybrid mess meant to force us to order them, if you ask me. Not sure you should try rigging it, best if you order them, you'll see what I mean when you get them. Sorry, we were in the same boat too. Wish I never bought this LG, but that's for another post.
Jun 30, 2009 | LG WM-2077C Front Load Washer
Need to secure for moving
You should have some bolts that came with the machine. They are fitted into the rear casing and screw into the drum to hold it steady. If you dont have the bolts then you can try packing some towels around the outside of the drum ( from underneath ) to hold it steady.
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
GE WSSH300 stops after wash and need to hit start again to finish
Be sure to rule out one of the simplest things first---be sure the button that gets depressed when you close the lid is still functioning (or even THERE) Sometimes, if you have had a severly offset load, this switch can become damaged. Some washers will not continue to advance if it " thinks" the door is opened.
May 09, 2009 | General Electric WSSH300G Front Load...
Color is off shade of red/ pink is on the skin of charaters
Repair solder joints on convergance IC's,but your best bet is just to go ahead and have them replaced.I highly advise that a TV tech preforms the work.
Apr 28, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Toshiba BD-7610 copier moved the copier down a
take the developer unit out carefully shake back and forth free spin the gears by hand clean any spill inside might work in the future remove dv and drum b 4 moving
Apr 09, 2009 | Toshiba Office Equipment & Supplies
Need to move front loading washer, how do i stabilize it to avoid damage in moving
order the locking pins that are inserted into the back to keep the drum set. Call the store you bought it from or a local mover to purchase.
Mar 26, 2009 | GE Energy Star WCVH6260F Front Load Washer
I need to move my Proform XP 620 treadmill down a flight of stairs. What is the best way to do this
Honestly, the best way to do this is to call an expert because any wrong adjustments to a treadmill can cause serious damage but if you want to attempt yourself you must try to move it whole with 2 people stronger holding the front of the tread as this is going to be the heaviest. Take the front down first down the stairs.
www.AtlantaFitnessRepair.com
Jan 19, 2009 | Proform XP Weight Loss 620 Treadmill
Moving the TV
you should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
Feb 13, 2008 | Hitachi 51SWX20B 51" Rear Projection...
GE WCVH6260F Front Load Washer Logo
1,489 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
