My head of the usb stick snapped off. ijust want the information off of it
  • 75 Answers
If the usb metal flat stick got snapped off,try to solder it back to its mini board, if you dont know how to solder..read from this site:
http://www.kpsec.freeuk.com/solder.htm
PS,rate pls... ;-)
Posted on Sep 25, 2008
Got an error code 5E00:021F
The error code suggests you can not get a response from the USB stick. Try another stick, try another port with the stick you have. Test the port where the stick did not operate with yet another stick. Check the device manager's report of the status of the driver for the device. Sadly, you have to test to see if you have a bad stick, a bad port, a bad driver! Run chkdsk. Run something like Speccy to see if it pulls up any information about the usb stick (with such inserted).
You essentially try to discover if the problem is with the stick itself or rather with the computer and or drivers. Here are some links to software that test USB sticks: https://www.raymond.cc/blog/how-to-check-and-test-usb-flash-drive/
If the problem is with Dell hardware, you might have to contact Dell. Dell has its own diagnostic programs you can try. http://nccumc.org/it/faq/how-to-run-hardware-diagnostics/
Of course a dreaded destructive recovery to factory defaults can often solve some of these problems. I would certainly try to access a system restore point pre-dating your problem before considering such an undesirable alternative. Research the error code on Dell's site; but I suspect it is general enough that there is not a ready answer.
Feb 16, 2015 | Dell XPS 420 PC Desktop
I had flash drive in my PC and it snapped off, leaving only the USB connector with 4 small prongs sticking out of the laptop. Can I recover this data. HELP!! Thank you.
Usb flash drive? its cut in half, can you tell me what kind of flash memory it is, do you know the brand and model that would help.
Jul 31, 2008 | Computers & Internet
Z5771
If all you want to do is remove/replace memory and hard drives no teardown of the is needed. Power down and unplug the computer.
*Remove the side cover. With a standard retail computer this can be a bit confusing; some have two screws on the rear of that side and the cover pops off. Others have hidden snaps or catches and the side comes off.
*Hard drives have either side screws holding them in, or some such as older Dells have plastic tabs that you gently pull out and the drive is free. Unplug the two cables on the drive.
*Memory: there are two small thumb snaps on each end of the memory stick that you push down and the memory pops free. Be careful replacing the sticks! Carefully line up the slot on the mounting socket on the motherboard with the plastic ridge on the stick, and press down firmly, first on one end and then on the other. You will see the small thumb snaps pop up as the stick settles in to the slot. Make sure the thumb snaps are fully upright, same as originally were.
Feb 05, 2014 | Acer Aspire Computers & Internet
Usb is not getting detected by win XP
1)first keep the pc turned on ]
2)then keep your head near the pc and stick your head and get up
3)then dance jingalala hoo hoo
Jan 15, 2011 | Computers & Internet
I noticed that when i play 320 resolution videos from my hard drive, they play perfect even in full screen. But when i play videos of 630 or 720 resolution, the video doesnt play right, it messes with my...
try using a new player...try Nero Showtime...and install latest codecs...."ffdshow" codec is good...search in google and install...
after install shutdown and restart...
Dec 17, 2009 | IBM PC 300PL PC Desktop
Ijust replaced the cpu fan and now the computer won't boot - it just flashes the gateway logo
make sure that the power reqs for the fan are the same as one you replaced and make sure that the new fan is the same prong (3 or 4). Also make absolutely sure you plugged the new fan power supply inti the CPU fan slot
Apr 15, 2009 | Computers & Internet
Getting somthing to help me get a printer to connected to the kid
If you are referring to the large parallel port that goes into desktops yes there is a convertor which will transfer this down to usb. You can find this at many computer parts shops onine or ebay. LPT1 to USB cable...
Dec 27, 2008 | Computers & Internet
Plse can u run thru the procedure to set up my new purchase pny 4gb flashdrive??
Most flashdrives (aka pen drives or usb sticks) do not require installation. They are a storage device that you add information to. If you could post your OS (either XP, Vista, Linux or Mac OS X) we can go through the process of adding and reading information from the drive.
Oct 20, 2008 | Computers & Internet
Ijust bought a new computer, it's vista and I try to download computer-checkup it takes me to screen name page and it just click and won't do anything else how can i fix it so i can download
I'm guessing it's something with IE 7. Is there a little information bar (yellow) across the top of the browser's viewable area? If so, click on it and look at your options.
Aug 26, 2008 | Computers & Internet
Memory stick
Hi Amanda,
All USB memory sticks/flashdrives uses the internal power supply of the device it is attached to (such as your DVD Rec/Player and your son's laptop). Having said that, once it is plug it is then made into an integral part of the device, if something is electrically wrong with it, the flashdrive will bring the whole device down. Technically, I suspect that the flashdrive has an internal short grounding the supply line. This is the "+5VDC rail" as we call it.
If you are seeking the services of an on-site repair person, it might help that this information be relayed to him/her as it will narrow down the diagnosis to the power supply section, fusible links/resistors, regulators and others of the sort.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 24, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
