Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
I bought the steamvac yesterday and the hose isn't in the box the assembly instructions show a small hose it is number 4 on the instruction sheet
    Scholar:
  • 157 Answers
Hello rap658. I suggest you contact the retailer or Mgfr. with this dilemma. Have your sales receipt and if you get a "I'm Sorry" reply ask for the MAIN BOSS, CHEIF HANCHO and during this have a note pade taking notes of name and their replies. Second base. Take same to Mgfr. on the phone. Third base. Contact Better Business Bureau, ditto. You will make it to home plate most likely with a brand new unit COMPLETE WITH ALL ATTACHMENTS. PLAY BALL!!!!
Posted on Oct 01, 2008
Attach the hose to a "hoover f7425 900 steamvac v2 widepath
click here> http://hoover.com/file/670/ for the manual it will give you full instructions how to attach the hose
Sep 25, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
I need to replace my hose to my steamvac model F5842 can you help? Ordered a hose but I don't think it's the right one
Hi Chris,
Your Hoover SteamVac model F5842 needs the Hoover SteamVac replacement hose part number 40309007. You may find a link to the correct hose for your model below on our website:
Hoover SteamVac F5842 Replacement Hose Assembly
In terms of replacing the hose, this is an older style SteamVac, which attaches the hose to the front of the Dirty Water Solution Tank.
Here is are instructions on how to attach the hose to your machine:
http://www.fixya.com/support/t4699742-dont_manual_u_connect_hose
Hopefully this was helpful, and answered your question. Please don't hesitate to request a clarification, or add a comment if you have any further questions or concerns.
Thanks,
Chris Jones
Oct 07, 2011 | Vacuums
Where do u attach the the hose to get suction for cleaning furniture?
Tried to track this down, but did not find anything specific. I did find a URL that shows the detachable hose with written instructions (very short) about attaching it to the unit. If you have the owners manual and go to the URL, you might be able to answer the question.
http://www.vacuumpartstore.com/mof59f59f59f.html
Paul
Oct 06, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Apr 10, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Need help with disassembly...
I would be happy to give to specific instructions. Please let me know the Model Number (starts with an F) and I will help.
Mar 10, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I bought a used hoover steamvac duo and I do not know how to use it. I need instructions please?
Go to www.hoover.com then, towards bottom left of the screen, click on "Download Manuals". This opens a search window, in which you can enter your model number and then download a copy of the manual.
If this solution has been helpful, please remember to rate me. Thanks!
Jan 22, 2010 | Hoover F5520 SteamVac Duo Upright Wet...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
41 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
