You may have a problem in the evaporator fan . Defrost fridge for 24 hours and start up. Problem should go away for some time. For a long term solution you need to check if defrost cycle is funtioning well if not suspect the timer or the heater.
i have a whirlpool fridge mo ER8MHMXML01. about 1 week ago the icemaker stopped making ice and wasnt...
(More)
i have a whirlpool fridge mo ER8MHMXML01. about 1 week ago the icemaker stopped making ice and wasnt cycling thought it might have ice frozen in it and thawed out freezer in case not it checked the waterline and have water but when i pulled the water tube at the back of the freezer i had none thinking it might be the solenoid any suggestions
food defrosting in freezer. has one control that I can see at top of refrigerator on top cold...
(More)
food defrosting in freezer. has one control that I can see at top of refrigerator on top cold setting.
The alarm keeps coming on with no fixed pattern. I have tried removing the cooler box as per the...
(More)
The alarm keeps coming on with no fixed pattern. I have tried removing the cooler box as per the instruction booklet. I have defrosted the fridge as per the instruction booklet. I have powerede the fridge down for an hour as per the instruction booklet. The alarm keeps coming on with the 6+7 green lights flashing. The temperature has been set at 5 (manufactures default and recommended setting). I have adjusted temp up and down to all settings with no effect. best regards Trevor
Is it worth it to replace and was there a reason it burned? The red wire was melted but I can spice...
(More)
Is it worth it to replace and was there a reason it burned? The red wire was melted but I can spice in a new connector.
