Question about Kitchen Ranges
How to run a frigidare stove from symbols on top panel
My son just moved into his new home. there is a frigidaire stove with symbols. no book explaining what the symbols are for. could you possibly help me. can't find a stove on internet like it.
thanking you in advance, the burners are black, smooth, raised just a touch, (not like the new stoves now) feel like hard granite or ceramic.
Jane Westwood
email: bingo123@cogeco.ca
SOURCE: Whirlpool electric stove
My sister has a whirlpool electric ceramic top stove/accubake sistem....the problem is that my husband took the door of the oven off to clean and now he can't get it back on......where on vacation at her house and want to fix it before we leave sept. 30/08. We need help fast.
thank you
Posted on Sep 28, 2008
  • 15 Answers
SOURCE: stove top burners not igniting
I would check that the range is plugged in first and that any fuse in the range itself has not blown. Fuse in the stove should be near where the electric line from the wall plug goes into the back of the range. Just follow it down to where it plugs into the range itself.
If all those are fine, check the little wires from the igniters all the way to where they plug into some connector. But unless you had a really busy mouse I dont see that happening to all the wires from each igniter. good luck
Posted on Oct 07, 2008
DeBruce
  • 145 Answers
SOURCE: black enamel stove top,frigidaire
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
SOURCE: How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
Posted on Sep 17, 2009
erpaalai
  • 999 Answers
SOURCE: How do I raise the stove top of a ceramic glass mo...
Open the oven door and look up across the front for 4 screws.
Eric
Posted on May 23, 2010
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
When the elements are on, the stove top in between the elements gets very hot. What could be the problem, and is it a safety concern? The stove has been like this ever since my son moved into his...
Sounds like the wires leading from one burner to the other are old/ frayed or bare and touching each other. Turn off the breaker (power), remove the top and check wires. They may need replacing. ~Denise
Jul 04, 2011 | Frigidaire Kitchen Ranges
None of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
My (new to me) apt has an electric jennair stove top -no instruct
Try http://www.jennair.com/flash.cmd?/#/page/home
Click on cooktops.
I have looked, but cannot find your model number. Perhaps if you look, you may be more sucessful, they do have pics and descriptions.
Oct 15, 2009 | Kitchen Ranges
Frigidare Gallery Range 1998 model convection/baking drop in range
Hi Juliett
huuum At your service!
You said,
You came home and the was no display showing - control panel seems completely dead - last time we used the stove the display was so dim it was hard to see.
_______________________________________________________________________________
I advice that you are correct!
From what I have read it sounds like a board should be replaced and the cost would be roughly $450 - is it worth it to call a tech or should I just buy a new one.
This like an expensive repair for an old range!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Buy New and save!
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Frigidaire has some good rebates this month!
Some Up to $750. cash back
Bless You,
huuum
Please give me a solved rating for this good advice at our web site before you sign off!
Sep 13, 2008 | Frigidaire FED367 Electric Kitchen Range
Black smooth stove top frigidare
Regular citrus cleaner/degreaser stuff, and careful use of a spatula to haul off the loosened bits. Then soap & water. How does this relate to the dishwasher...did you think you could evert the stomach of the dishwasher over the stove or something, like a mechanical starfish attacking a metal ****?
Aug 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Fault code F5
Hi Marcos
Happy to help you!
But I see that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Aug 05, 2008 | Frigidaire PLEF398AC Electric Kitchen...
F1 - oven will not turn on
You can try turning the power off for a couple minutes then back on but this is typically caused by a stuck key or a faulty control board. Either way you're looking at needing a new control board.
Hope this helps.
Dec 20, 2007 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen Ranges Logo
135 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
