Question about Dell E153FPT 15" Flat Panel LCD Monitor
Power problem my dell E153FPc monitor has no power-it is completly dead. how can i troubleshoot & repair it?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 848 Answers
Power problem? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1521HSD1 715L1074 PWPC1521XXD1 Dell ADTV1521HSD1 Power Supply Backlight...
Posted on Feb 11, 2015
For the quickest fix, you should try a new power supply cord and see if its just a bad cable. almost any monitor cable (dell brand) should work. if you do not see any of the lights on the monitor light up then you have an internal problem and it will be costly to repair. probably better of buying a new monitor.
Posted on Nov 13, 2008
Dell E2210 monitor inverter ic for ccfl
http://www.electronicrepairguide.com/dell-e153fpc-lcd-monitor-repair.html
Jan 13, 2016 | Dell Computers & Internet
My Dell Monitor model E153FPc will not turn on or, if on, will not turn off. We tried leaving it on, but sometimes the on/off button would just flash, but nothing came on the screen. I am trying to open...
See video here, it close to the same model as yours: http://www.lcdrepair.us/E172fpbvideo.html
Boards: http://www.lcdrepair.us/Invpowersupply.html
Look for bad caps first:
http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPC/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELLS monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 15, 2011 | Dell E153FPc 15" TFT LCD Flat Panel...
My Dell E153FPc 15" shuts
Look for cold solder joints, shorted transistors, bad fuse, bad caps.
See pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Replacement board: http://www.lcdrepair.us
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Feb 02, 2011 | Dell E153FPc 15" TFT LCD Flat Panel...
My sreen is dark on my dell E153FPc when i cut it on i can see but it goes dark after like 2 seconds is it the contrast
Not hte setting problem, but more likely to be problem in the power supply /inverter circuits due to bad caps, shorted transistors, cold solder joints.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 26, 2010 | Dell E153FPc 15" TFT LCD Flat Panel...
Why does my e153fpc go blank one second after turn on
Guest, Learn "flashlight test" first!! Point bright flashlight at screen (1 inch away) when screen goes black!!! Is Dell E153FP BLANK n BLACK? Or is it just BLACK? Can you still see very faint image of the icons and Win-desktop? If you read my fixya profile for a while you should then get back to me and tell me what you will do to restore unit to working order. There are lots of DIY video clips at YOUTUBE that will help you determine if you will do the repair or contract-out the work. DIY is still the cheapest way to go if you are handy with a oldering pencil and solder. Do your research first!!! All the cold-cathode-fluorescent-lamp-back-lit lcd monitor techs here on fixya already know you have a good chance to repair it. Just do some reading and follow the links you find for all the info you need. 12fixlouie
May 15, 2010 | Computers & Internet
Is there a way to open the monitor case to fix the backlight without using a hammer and chisel . . ? Dell Model #E153FPc
Yes the screens are held together by screws and clips. you need an electronics plastic opening tool to not damage them but they are repairable without having the damage them.
Feb 12, 2010 | Dell E153FPc 15" TFT LCD Flat Panel...
Dell E153FPc switches off (black Screen) after a few minutes. If you switch it off & back on again it will stay on for a few minutes, then go off again.
You could have an inverter board problem. The inverter supplies high voltage to the CCFL lamp which provides the back-lighting.
For service. parts and DIY info check out LCD Parts - click in this link to their WEB site : -
www.lcdparts.net
Oct 16, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
No power
check your powers suplly waltage and earthing properly.change your power cable of lcd monitor.
reconect it.fix it proerly.then try u can do it.
Feb 09, 2009 | Dell E153FP 15" LCD Monitor
Dell E153FPT 15" Flat Panel LCD Monitor Logo
196 people viewed this question
Alun Cox
