Question about Xerox DOCUMATE 510 Flatbed Scanner
When scanning color document, blue tone is present as background shade
When scanning any document, the scanned image always has a blue tone to the final document. When scanning a black & white text document the end product appears to have been done with a blue colored paper with black text on the top.
Any suggestions???
    Problem Solver:
  • 12 Answers
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Posted on Aug 20, 2009
Scanner Model is Kodak i4200. Whenever I scan a document in Color Mode the background is filled with BLUE color. This doesn't happen when I scan in B/W mode. Can you please help ?
If you are talking about a blue tinge Try turning on background smoothing in the driver under adjustments that may sort it or adjust the brigtness and contrast a little if that doesnt solve it Image calibration is the next step you will need to contact Kodak as its not a user function
Jan 09, 2015 | Kodak i4200 - document scanner
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
Problem in my Scanner
Hi
Supports user-specified installation
Removes unwanted blue cast from scanned color images.Update your Driver , Click the below link for your scanner Model
http://driveragent.com/archive/10242/64-1-531?q=microtek+3880+scanner+displays+blue+shade
Jan 01, 2010 | Microtek scanmaker 3840
My scanner hp3570c has developed this problem since some time now, it scans but the white background is always in some megenta tone and the mater appears in green and blue. please advice what the problem...
you need to depress the original onto the scanner it could be the scanner is not fully resting on the flat surface, or not fully closed, say for example there is a big gap on the scanner and the white plate, try scanning a single sheet only and see if you have the same prob. i assume you are scanning a book or thick material or something, the colored images you see is the reflection of the scanner that goes astray from the actual images that needs to be scanned, the light that was exposed without the white plate reflected was converted into Green and Blue, pls try .
Jul 10, 2009 | HP ScanJet 2400 Flatbed Scanner
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Scanning documents
try to adjust properly the before scanning option
make it scan the whole page
if this not help tell me so i can help u further
plaese rate this post
Aug 23, 2008 | Canon Pixma MP800 All-In-One InkJet...
All scanned documents have blue background.
You have to take the machine to service partner who can be found on the brother homepage of your country.(www.brother.com)
The scanner needs calibration which can only be done by service personel.
Dec 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Oct 19, 2007 | Canon DR-1210C Scanner
Xerox DOCUMATE 510 Flatbed Scanner Logo
1,303 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
